Up to 20% off select tools
Disassembling Nerf Recon CS-6 Shell
Views: 13K
View statistics:
Past 24 Hours:
6
Past 7 Days:
35
Past 30 Days:
136
All Time:
13,389
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is a prerequisite to replacing any other piece. This guide involves removing most of the screws in the shell and splitting the gun along the middle seam.
    1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: step 1, image 1 of 1
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      Ask FixBot
    2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: step 2, image 1 of 1
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      Ask FixBot
    3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: step 3, image 1 of 2 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: step 3, image 2 of 2
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      Ask FixBot
    4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: step 4, image 1 of 1
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      Ask FixBot
    5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: step 5, image 1 of 1
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      Ask FixBot
    6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: step 6, image 1 of 2 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: step 6, image 2 of 2
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      Ask FixBot
12 other people completed this guide.
Author
with
Asad Qureshi
595 Reputation
3 Guides authored
Baylor, Team 8-14, Williams Fall 2014 Member of Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Members
72 Guides authored
2 Guide Comments
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - Reply Share
very useful, thanks!
Sebastian Isaacs - Reply Share
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 136
All Time: 13,389
