Up to 20% off select tools
Disassembling NEC LCD1770NX Stand
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
110
All Time:
1,985
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the stand from the rest of the monitor allows you to access and replace parts inside the display assembly.
Before beginning this guide, prepare a clean, flat surface to use as a workstation. Avoid working over carpeting, as small screws are used and, if dropped, may be lost in the carpet.
    1. Disassembling NEC LCD1770NX Stand, Stand: step 1, image 1 of 2 Disassembling NEC LCD1770NX Stand, Stand: step 1, image 2 of 2
      • Place the monitor face down on a clean, flat surface.
      Ask FixBot
    2. Disassembling NEC LCD1770NX Stand: step 2, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 2, image 2 of 2
      • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
      Ask FixBot
    3. Disassembling NEC LCD1770NX Stand: step 3, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 3, image 2 of 2
      • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
      Ask FixBot
    4. Disassembling NEC LCD1770NX Stand: step 4, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 4, image 2 of 2
      • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
      Ask FixBot
    5. Disassembling NEC LCD1770NX Stand: step 5, image 1 of 1
      • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
      Ask FixBot
    6. Disassembling NEC LCD1770NX Stand: step 6, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 6, image 2 of 2
      • Lift the the stand straight up to remove it.
      Ask FixBot
Author
with
Michela Upson
110 Reputation
1 Guide authored
Cal Poly, Team 11-36, Amido Fall 2013 Member of Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 110
All Time: 1,985
