Up to 20% off select tools
Disassembling Motorola i850 Keypad
Views: 2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
23
All Time:
2,040
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A procedure in replacing the keypad of the device.
    1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: step 1, image 1 of 1
      • Use your thumb to slide the back cover locker away from the antenna.
      Ask FixBot
    2. Disassembling Motorola i850 Keypad: step 2, image 1 of 2 Disassembling Motorola i850 Keypad: step 2, image 2 of 2
      • Slide the back cover towards the antenna while lifting the cover away from the phone.
      Ask FixBot
    1. Disassembling Motorola i850 Keypad, Battery: step 3, image 1 of 1
      • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
      Ask FixBot
    2. Disassembling Motorola i850 Keypad: step 4, image 1 of 2 Disassembling Motorola i850 Keypad: step 4, image 2 of 2
      • Lift the battery out of the phone while pushing it towards the antenna.
      Ask FixBot
    1. Disassembling Motorola i850 Keypad, Keypad: step 5, image 1 of 1
      • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
      Ask FixBot
    2. Disassembling Motorola i850 Keypad: step 6, image 1 of 3 Disassembling Motorola i850 Keypad: step 6, image 2 of 3 Disassembling Motorola i850 Keypad: step 6, image 3 of 3
      • Grip the device firmly with both hands and carefully open the device.
      • Warning: Be incredibly careful removing the back panel as you may tear the flex cable connecting the loudspeaker and side buttons.
      Ask FixBot
    3. Disassembling Motorola i850 Keypad: step 7, image 1 of 2 Disassembling Motorola i850 Keypad: step 7, image 2 of 2
      • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
      Ask FixBot
    4. Disassembling Motorola i850 Keypad: step 8, image 1 of 2 Disassembling Motorola i850 Keypad: step 8, image 2 of 2
      • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
      Ask FixBot
    5. Disassembling Motorola i850 Keypad: step 9, image 1 of 3 Disassembling Motorola i850 Keypad: step 9, image 2 of 3 Disassembling Motorola i850 Keypad: step 9, image 3 of 3
      • Place the back of the device on your hand and flip it over with the other hand.
      • Carefully lift the device to remove interior hardware.
      • The structure of the keypad should easily be loose from flipping the device.
      Ask FixBot
    6. Disassembling Motorola i850 Keypad: step 10, image 1 of 3 Disassembling Motorola i850 Keypad: step 10, image 2 of 3 Disassembling Motorola i850 Keypad: step 10, image 3 of 3
      • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
      • WARNING: The plastic keypad is sensitive and can be easily damaged.
      Ask FixBot
Author
with
Tony Chen
1 Reputation
1 Guide authored
Cal Poly, Team 34-56, Forte Spring 2010 Member of Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 2,040
