Up to 20% off select tools
Disassembling Motorola E815 Antenna
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
77
All Time:
2,852
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Introduction
Go to step 1 ↓
Reception issues or a broken antenna may mean the antenna needs to be replaced. In this guide, you are going to:
  • Access the antenna
  • Remove the antenna
NOTE: This guide shows the E815 partially dissembled. Disassembly is not required to access the antenna.
    1. Disassembling Motorola E815 Antenna, Disassembling Motorola E815 Antenna: step 1, image 1 of 1
      • Locate the antenna port on the top of the phone.
      Ask FixBot
    2. Disassembling Motorola E815 Antenna: step 2, image 1 of 2 Disassembling Motorola E815 Antenna: step 2, image 2 of 2
      • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
      • Pull the apparatus up and out of the phone.
      Ask FixBot
Author
with
Zoie E
603 Reputation
5 Guides authored
Cal Poly, Team 14-8, Forte Winter 2011 Member of Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 77
All Time: 2,852
