Up to 20% off select tools
Disassembling Motorola Droid Camera
Views: 3.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
91
All Time:
3,416
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • T5 Torx Screwdriver
    4.9
Introduction
Go to step 1 ↓
You've already gotten To the Camera Assembly, so why not go just a bit further? Lint can easily get in and wreak havoc with the micro-ball-bearings found within the camera assembly, and cleaning the assembly iis quite straightforward. Beware: Really Teeny Parts ahead!!
    1. Disassembling Motorola Droid Camera, Battery: step 1, image 1 of 3 Disassembling Motorola Droid Camera, Battery: step 1, image 2 of 3 Disassembling Motorola Droid Camera, Battery: step 1, image 3 of 3
      • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
      • Lift and remove the battery cover out from the phone.
      Ask FixBot
    2. Disassembling Motorola Droid Camera: step 2, image 1 of 1
      • Grasp the upper left corner of the battery and lift it out of its housing.
      Ask FixBot
    1. Disassembling Motorola Droid Camera, Rear Case: step 3, image 1 of 1
      • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
      • The cover is attached by adhesive, so some force may be required.
      Ask FixBot
    2. Disassembling Motorola Droid Camera: step 4, image 1 of 2 Disassembling Motorola Droid Camera: step 4, image 2 of 2
      • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
      • Peel the ribbon up off the phone.
      Ask FixBot
    3. Disassembling Motorola Droid Camera: step 5, image 1 of 2 Disassembling Motorola Droid Camera: step 5, image 2 of 2
      • Carefully peel the device information label that covers the motherboard EMI shields.
      • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
      Ask FixBot
    4. Disassembling Motorola Droid Camera: step 6, image 1 of 1
      • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
      • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
      Ask FixBot
    5. Disassembling Motorola Droid Camera: step 7, image 1 of 1
      • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
      Ask FixBot
    6. Disassembling Motorola Droid Camera: step 8, image 1 of 1
      • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
      Ask FixBot
    7. Disassembling Motorola Droid Camera: step 9, image 1 of 1
      • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
      • Carefully pry the top edge of the rear case up from the rest of the phone.
      Ask FixBot
    8. Disassembling Motorola Droid Camera: step 10, image 1 of 2 Disassembling Motorola Droid Camera: step 10, image 2 of 2
      • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
      • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
      Ask FixBot
    9. Disassembling Motorola Droid Camera: step 11, image 1 of 2 Disassembling Motorola Droid Camera: step 11, image 2 of 2
      • Continue prying the rear case from the front case along the left side, moving from bottom to top.
      • Lift the rear case up out of the phone.
      Ask FixBot
    1. Disassembling Motorola Droid Camera, Speaker: step 12, image 1 of 1
      • Carefully lift and remove the speaker assembly up out of the phone.
      Ask FixBot
    1. Disassembling Motorola Droid Camera, Motherboard: step 13, image 1 of 3 Disassembling Motorola Droid Camera, Motherboard: step 13, image 2 of 3 Disassembling Motorola Droid Camera, Motherboard: step 13, image 3 of 3
      • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
      • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
      Ask FixBot
    2. Disassembling Motorola Droid Camera: step 14, image 1 of 1
      • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
      Ask FixBot
    3. Disassembling Motorola Droid Camera: step 15, image 1 of 1
      • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
      Ask FixBot
    4. Disassembling Motorola Droid Camera: step 16, image 1 of 1
      • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
      Ask FixBot
    5. Disassembling Motorola Droid Camera: step 17, image 1 of 1
      • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
      • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
      Ask FixBot
    6. Disassembling Motorola Droid Camera: step 18, image 1 of 2 Disassembling Motorola Droid Camera: step 18, image 2 of 2
      • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
      • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
      • Remove the motherboard from the phone.
      Ask FixBot
    1. Disassembling Motorola Droid Camera, Camera Assembly: step 19, image 1 of 2 Disassembling Motorola Droid Camera, Camera Assembly: step 19, image 2 of 2
      • Orient the motherboard so that the camera lens is face down.
      • Disconnect the camera connector from its socket by prying it straight up with a spudger.
      • Remove the camera assembly.
      Ask FixBot
    1. Disassembling Motorola Droid Camera, Disassembling Motorola Droid Camera: step 20, image 1 of 1
      • Use a flat jewelers screwdriver to gently pry up the housing surrounding the Camera lens. Pry up one side first, then the other.
      • Note the orientation of the Dimple on the side of the cover, as it will need to go on the same way during Reassembly.
      Ask FixBot
    2. Disassembling Motorola Droid Camera: step 21, image 1 of 1
      • With the cover off, you can now see the top of the Lens holder, and immediately next to that the white Micro-Ball-Bearing shuttle. Normally, the Lens Holder should somewhat easily raise and lower, but if you are This far into it, chances are that it isn't moving easily.
      Ask FixBot
    3. Disassembling Motorola Droid Camera: step 22, image 1 of 1
      • To lift out the Lens Holder, use a Pin to carefully lift an edge of the Lens Holder.
      • WARNING: Don't just turn over the assembly and tap it on the work surface: You can Easily lose the Micro-Ball-Bearing shuttle!!
      Ask FixBot
    4. Disassembling Motorola Droid Camera: step 23, image 1 of 1
      • With the Lens holder lifted, the Micro-Ball-Bearing shuttle will simply fall into the cavity: Gently tip out the shuttle onto your work surface.
      • DON'T SNEEZE! That Micro-Ball-Bearing shuttle is quite lightweight, indeed!!
      • The CCD is at the Bottom of the Cavity: Please respect it,and dont touch it with anything dirty!!
      Ask FixBot
3 other people completed this guide.
Author
with
Stego
165 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 91
All Time: 3,416
