Up to 20% off select tools
Disassembling Motorola Defy XT
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
94
All Time:
1,657
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Disassembling Motorola Defy XT, Disassembling Motorola Defy XT: step 1, image 1 of 1
      • Switch off the mobile.
      Ask FixBot
    2. Disassembling Motorola Defy XT: step 2, image 1 of 1
      • Unlock the back case before open.
      Ask FixBot
    3. Disassembling Motorola Defy XT: step 3, image 1 of 1
      • Remove the battery
      • Remove the memory card
      • Remove the Sim card
      Ask FixBot
    4. Disassembling Motorola Defy XT: step 4, image 1 of 2 Disassembling Motorola Defy XT: step 4, image 2 of 2
      • Remove 6 screws
      • Tear off a part of label
      • Release the usb cover
      Ask FixBot
    5. Disassembling Motorola Defy XT: step 5, image 1 of 1
      • Open the green case part by yours fingernail from left side to the right side with the usb socket
      • Be care of your labels
      • If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
      Ask FixBot
    6. Disassembling Motorola Defy XT: step 6, image 1 of 2 Disassembling Motorola Defy XT: step 6, image 2 of 2
      • To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
      • 1. Touchscreen adapter
      • 2. Sticker between the touchscreen PCB & mobile PCB
      • Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
      Ask FixBot
    7. Disassembling Motorola Defy XT: step 7, image 1 of 3 Disassembling Motorola Defy XT: step 7, image 2 of 3 Disassembling Motorola Defy XT: step 7, image 3 of 3
      • You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
      • That finger pin is left by the Motorola Support Center in Hong Kong!!
      • You can also clean the camera lens on PCB
      Ask FixBot
    8. Disassembling Motorola Defy XT: step 8, image 1 of 1
      • Remember to put all parts back and insert the touchscreen plugs slightly.
      • Put the green case back, make sure all locks is conneted
      Ask FixBot
    9. Disassembling Motorola Defy XT: step 9, image 1 of 1
      • You can test the mobile before screw.
      • After insert the memory card, SIM card and battery, switch on the phone
      • Test call in and call out, also check the speaker
      • Open the map Apps to test Wifi and GPS
      • Bluetooth file transfer
      • Camera test and save in sd card
      • Check the sd card files
      • Try to connect with PC
      Ask FixBot
    10. Disassembling Motorola Defy XT: step 10, image 1 of 3 Disassembling Motorola Defy XT: step 10, image 2 of 3 Disassembling Motorola Defy XT: step 10, image 3 of 3
      • If all works, remove the SIM card and battery.
      • Recheck the label is it on the top of the green case
      • Screws up all 6 screws
      • Put back all battery and SIM card
      • Close the back case and lock it
      • Close the USB cover
      • Done
      Ask FixBot
    11. Disassembling Motorola Defy XT: step 11, image 1 of 3 Disassembling Motorola Defy XT: step 11, image 2 of 3 Disassembling Motorola Defy XT: step 11, image 3 of 3
      • If you want to explore what inside of the battery with PCB. Here is the step to follow.
      • Remove the label
      • Remove the black rubber
      • Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
      • Also you can tear PCB by hand
      Ask FixBot
    12. Disassembling Motorola Defy XT: step 12, image 1 of 1
      • Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
      Ask FixBot
    13. Disassembling Motorola Defy XT: step 13, image 1 of 1
      • ***do not use any metal tools to cut it out!!
      Ask FixBot
    14. Disassembling Motorola Defy XT: step 14, image 1 of 1
      Ask FixBot
2 other people completed this guide.
Author
with
Wing Nga PANG
151 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 94
All Time: 1,657
