Up to 20% off select tools
Disassembling Motorola Cliq Rear Casing
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
96
All Time:
1,222
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This is ONLY a prerequisite guide to remove the rear casing in the Motorola Cliq.
    1. Disassembling Motorola Cliq Rear Casing, Battery: step 1, image 1 of 2 Disassembling Motorola Cliq Rear Casing, Battery: step 1, image 2 of 2
      • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
      Ask FixBot
    2. Disassembling Motorola Cliq Rear Casing: step 2, image 1 of 2 Disassembling Motorola Cliq Rear Casing: step 2, image 2 of 2
      • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
      • The pull tab may be tucked under the battery.
      Ask FixBot
    1. Disassembling Motorola Cliq Rear Casing, Rear Casing: step 3, image 1 of 3 Disassembling Motorola Cliq Rear Casing, Rear Casing: step 3, image 2 of 3 Disassembling Motorola Cliq Rear Casing, Rear Casing: step 3, image 3 of 3
      • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
      • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
      Ask FixBot
    2. Disassembling Motorola Cliq Rear Casing: step 4, image 1 of 1
      • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
      Ask FixBot
    3. Disassembling Motorola Cliq Rear Casing: step 5, image 1 of 3 Disassembling Motorola Cliq Rear Casing: step 5, image 2 of 3 Disassembling Motorola Cliq Rear Casing: step 5, image 3 of 3
      • Turn the phone over and slide out the keyboard.
      • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
      • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
      • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
      Ask FixBot
    4. Disassembling Motorola Cliq Rear Casing: step 6, image 1 of 1
      • Carefully separate the back casing from the rest of the phone.
      Ask FixBot
    5. Disassembling Motorola Cliq Rear Casing: step 7, image 1 of 2 Disassembling Motorola Cliq Rear Casing: step 7, image 2 of 2
      • Gently pry ZIF connector upwards using the flat end of a spudger tool.
      • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
      • You may need adhesive to keep your power cable in place when reassembling your phone.
      Ask FixBot
    6. Disassembling Motorola Cliq Rear Casing: step 8, image 1 of 3 Disassembling Motorola Cliq Rear Casing: step 8, image 2 of 3 Disassembling Motorola Cliq Rear Casing: step 8, image 3 of 3
      • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
      • The rear casing and the rest of the phone should now be completely separated.
      Ask FixBot
3 other people completed this guide.
Author
with
Tony Tran
84 Reputation
8 Guides authored
Cal Poly, Team 10-42, Amido Spring 2013 Member of Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 96
All Time: 1,222
