Disassembling Miele CM7 Coffee Maker Unit case
    1. Disassembling Miele CM7 Coffee Maker Unit case, Water tank side: step 1, image 1 of 2 Disassembling Miele CM7 Coffee Maker Unit case, Water tank side: step 1, image 2 of 2
      • Remove the cover by simply pulling it.
      • Unscrew 2 screws (T10).
      Ask FixBot
    2. Disassembling Miele CM7 Coffee Maker Unit case, Brewing unit side: step 2, image 1 of 1
      Ask FixBot
    3. Disassembling Miele CM7 Coffee Maker Unit case, Remove the top panel: step 3, image 1 of 2 Disassembling Miele CM7 Coffee Maker Unit case, Remove the top panel: step 3, image 2 of 2
      • Using a plastic spudger, carefully pry the top open, beginning with the back of the unit.
      • Once the top is slightly open, slide for about 1/8 inch to the back, then flip it to unplug the cup heater.
      Ask FixBot
    4. Disassembling Miele CM7 Coffee Maker Unit case, Remove the back panel: step 4, image 1 of 2 Disassembling Miele CM7 Coffee Maker Unit case, Remove the back panel: step 4, image 2 of 2
      • At the back side, unscrew 2 screws (T10).
      • Then lift the back for about 1/8 inch, then pull it.
      Ask FixBot
    5. Disassembling Miele CM7 Coffee Maker Unit case, Remove the side door panel: step 5, image 1 of 1
      • Looking from the back, pry on the tab then lift the door up for about 1/8 inch.
      Ask FixBot
    6. Disassembling Miele CM7 Coffee Maker Unit case, Views from the inside: step 6, image 1 of 2 Disassembling Miele CM7 Coffee Maker Unit case, Views from the inside: step 6, image 2 of 2
      • Pictures of the front top, and back (rotated 90° to fit here).
      Ask FixBot
Ballon Lac
364 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 11
Past 30 Days: 42
All Time: 299
