Up to 20% off select tools
Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
Views: 2.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
95
All Time:
2,775
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show the user of this scanner how to take apart the chassis so they can repair inside components.
    1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: step 1, image 1 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: step 1, image 2 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: step 1, image 3 of 3
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      Ask FixBot
    2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: step 2, image 1 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: step 2, image 2 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: step 2, image 3 of 3
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      Ask FixBot
    1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: step 3, image 1 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: step 3, image 2 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: step 3, image 3 of 3
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      Ask FixBot
    2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: step 4, image 1 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: step 4, image 2 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: step 4, image 3 of 3
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      Ask FixBot
    3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: step 5, image 1 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: step 5, image 2 of 3 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: step 5, image 3 of 3
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      Ask FixBot
Author
with
Taylor Nesheim
59 Reputation
7 Guides authored
Cal Poly, Team 6-9, Regan Fall 2011 Member of Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 95
All Time: 2,775
