Up to 20% off select tools
Disassembling Mercedes W123 Kick Panel
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
133
All Time:
16,450
Comments: 1
1 guide comment.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your blower motor is making noise, you need to check your A/C for leaks inside the car, or you need to remove your instrument cluster you will need to pull one or both of your kick panels. Don't let it get in the way of your doing your own diagnosis and work! This guide uses the passenger side kick panel as the example, the driver's side is basically the same.
    1. Disassembling Mercedes W123 Kick Panel, Kick Panel: step 1, image 1 of 1
      • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
      Ask FixBot
    2. Disassembling Mercedes W123 Kick Panel: step 2, image 1 of 1
      • Then remove these screws.
      Ask FixBot
    3. Disassembling Mercedes W123 Kick Panel: step 3, image 1 of 2 Disassembling Mercedes W123 Kick Panel: step 3, image 2 of 2
      • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
      Ask FixBot
    4. Disassembling Mercedes W123 Kick Panel: step 4, image 1 of 2 Disassembling Mercedes W123 Kick Panel: step 4, image 2 of 2
      • Now lower the panel down and rest if on the floor.
      • It can be removed full for further ease of access, depending on the job at hand.
      Ask FixBot
    5. Disassembling Mercedes W123 Kick Panel: step 5, image 1 of 3 Disassembling Mercedes W123 Kick Panel: step 5, image 2 of 3 Disassembling Mercedes W123 Kick Panel: step 5, image 3 of 3
      • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
      • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
      • Heater blower motor
      • Over-voltage protection relay
      • Air-conditioning expansion valve
      Ask FixBot
11 other people completed this guide.
Author
with
Nicolas Siemsen
40,598 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
1 Guide Comment
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 133
All Time: 16,450
