Up to 20% off select tools
Disassembling Mercedes W123 Door Panel
Views: 42K
View statistics:
Past 24 Hours:
7
Past 7 Days:
42
Past 30 Days:
209
All Time:
41,697
Comments: 7
4 comments on steps, 3 guide comments.
Go to guide comments
Completed: 42
42 people have marked this guide "completed." Will you be next?
Favorites: 20
20 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
In order to repair items such as your window regulators or door lock vacuum actuators, and to properly lubricate your lock mechanisms, you will need to pull your door panel. This is not difficult, but there are some little tricks and "hidden" screws that can make it challenging the first time. Learn to properly remove your panel with this guide. This will allow you to easily move on to the more important projects lying behind the panel.
    1. Disassembling Mercedes W123 Door Panel, Door Panel: step 1, image 1 of 1
      • Begin by removing the door lock knob. It unscrews counter-clockwise.
      Ask FixBot
    2. Disassembling Mercedes W123 Door Panel: step 2, image 1 of 1
      • Remove the two screws that attach the chrome trim around the door latch. The chrome trim will come loose afterwards. Set aside.
      • Note: the screws shown are not original. Phillips head screws are the original equipment. These are 2.5mm allen head screws.
      Ask FixBot
    3. Disassembling Mercedes W123 Door Panel: step 3, image 1 of 1
      • Use a flat blade screwdriver to gently pry out the black plastic cover behind the door pull.
      Ask FixBot
    4. Disassembling Mercedes W123 Door Panel: step 4, image 1 of 3 Disassembling Mercedes W123 Door Panel: step 4, image 2 of 3 Disassembling Mercedes W123 Door Panel: step 4, image 3 of 3
      • Remove the screw that holds the chrome plate behind the door pull.
      • Once again, the 2.5mm allen screw shown is not original. This will normally be a Phillips screw.
      • On the driver's side door, with no upper section of the arm on the door panel, the chrome panel behind the door pull can simply be removed and set aside at this point.
      Ask FixBot
    5. Disassembling Mercedes W123 Door Panel: step 5, image 1 of 2 Disassembling Mercedes W123 Door Panel: step 5, image 2 of 2
      • On the other three doors, the chrome panel is a part of the upper arm on the door panel. Pull the chrome panel out from behind the door pull. You will need to pull the door pull away from the door to get the chrome panel around it. It will move down the arm on the door panel.
      Ask FixBot
    6. Disassembling Mercedes W123 Door Panel: step 6, image 1 of 1
      • Remove the large Phillips head screw at the very top of the arm on the panel.
      • This step does not apply to the driver's door.
      Ask FixBot
    7. Disassembling Mercedes W123 Door Panel: step 7, image 1 of 1
      • Under the arms on all four doors, there are two large Phillips screws. They are hidden out of sight up in holes like the one pictured. Making sure to properly seat the screwdriver in the head, as to not strip the screw, loosen these screws.
      • There is no need to remove the screws from the holes in the arm; in fact, doing so will make it more difficult to re-install them. Just loosen them enough to remove the arms from the panels.
      Ask FixBot
    8. Disassembling Mercedes W123 Door Panel: step 8, image 1 of 3 Disassembling Mercedes W123 Door Panel: step 8, image 2 of 3 Disassembling Mercedes W123 Door Panel: step 8, image 3 of 3
      • For doors with manual windows, you will need to remove the crank before removing the panel.
      • Use a finger to push the tab that holds the trim piece to the crank out until it clears the crank.
      • Pull trim toward the knob on the crank to release the trim.
      • The trim piece will release from the peg at the base of the crank. The crank will now slide off.
      • When reassembling the manual window crank, make sure the tapered end of the washer is facing away from the door.
      • The tapered washer is sometimes missing. It is used to protect the panel from wear.
      Ask FixBot
    9. Disassembling Mercedes W123 Door Panel: step 9, image 1 of 2 Disassembling Mercedes W123 Door Panel: step 9, image 2 of 2
      • Using a wide pry tool, like this trim removal tool, go around the edge of the panel between it and the metal part of the door. You will find it held in place by plastic clips. Gently pry each clip out all the way around.
      • On an older car like the W123, there will likely be some broken clips. Some times, panels are being held in place by only two or three clips.
      • Be aware that even though there should be no screws holding the panel to the door at this point, you will want to carefully check that someone didn't use a screw in the past to make up for broken clips. If you try and pull it off without removing the screw, you could damage your panel.
      Ask FixBot
    10. Disassembling Mercedes W123 Door Panel: step 10, image 1 of 1
      • On the rear doors, you will need to unplug the window switch from the plug and wire harness in the door before finally removing the panel.
      Ask FixBot
    11. Disassembling Mercedes W123 Door Panel: step 11, image 1 of 1
      • Remove the panel by pulling up on it. Do not pull straight out on the panel, or it may bend. This cannot be repaired. Pulling up on the panel before pulling out on it will also help ensure that you do not damage the plastic clips on the back of the map pocket on the door panel (only applies to front panels; rear panel shown in this picture).
      Ask FixBot
    12. Disassembling Mercedes W123 Door Panel: step 12, image 1 of 3 Disassembling Mercedes W123 Door Panel: step 12, image 2 of 3 Disassembling Mercedes W123 Door Panel: step 12, image 3 of 3
      • Pictured is the back of your door panel once removed. Notice the white plastic clips around the edge. Notice that many are missing. There should be several more on this door. Also, notice that some are broken.
      • Once the panel is removed, there should be a plastic vapor barrier between the panel and the door shell. This will need to be removed. If removed gently, it may be able to be reused. Otherwise, replace it with any thick plastic and 3M Spray Adhesive or contact cement. (Not pictured)
      Ask FixBot
    13. Disassembling Mercedes W123 Door Panel: step 13, image 1 of 2 Disassembling Mercedes W123 Door Panel: step 13, image 2 of 2
      • This is a list of the major components within the door (front passenger side shown):
      • Window regulator (note, the rear window regulators are designed differently and are not immediately visible)
      • Door lock vacuum actuator, early style (does not apply to driver's door, which is equipped with the master vacuum switch instead, see attached picture). On later W123's, the actuators are in similar locations but look different.
      • Door pull
      • Door latch and lock mechanisms
      • Master vacuum switch (driver's door). Note that on later models the master switch will be oriented vertically instead of horizontally.
      Ask FixBot
42 other people completed this guide.
Author
with
Nicolas Siemsen
40,598 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
3 Guide Comments
W114 is similar, except clips are metal. On the coupe, there is also a small screw holding in the lock lever chrome surround (there is no lock stem type knob in the coupe).
David Iwanicki - Reply Share
Nicolas, thanks for your  instructions, your clear color coded photos!!!! Thanks to you, I fixed my vacuum issues and now doors lock, engine shuts off and it shifts better!!   Bob Neimeyer
Bob - Reply Share
Schönen guten Tag!
Ich habe Probleme mit der Zentralverriegelung meines DB W1123, 230 CE, Bj. 1982. Beide Türen. Kofferklappe Tankverschluss keine Funktion, Motor lief nach Kaltstart nicht richtig rund. Hinter Motor 3 Ventile, sind o.k, am unteren Ventil (wohl Ersatz für Zweierverteiler) 1 Anschluss gelb mit grauem Streifen am Ventilanschluss war wohl nicht mehr dicht. Tank unter der Hutablage oben im Kofferraum i.O.. Der 2. Schlauch gelb. Mit Pumpe (gelb mit grau und nur gelb) Unterdruckbehälter und System abgepumpt. Dann Kofferklappe, Tankverschlussdeckel, Beifahrertür getestet, nur Beifahrertür keine Reaktion! Türverkleidung abbauen, soweit kein Problem, alle Klammern o.k. Am Bereich der Türhalterung kann man die Verkleidung nicht lösen, so fest wie angeschraubt, aber keine Schraube in Sicht. Welches Problem/Lösung gibt es hier? Außerdem ist Tür an der Scheibenkurbel auch fest. Wie Verkleidung nun zu entnehmen?
Gruß Reinhard 0173 5803960
A
Reinhard Heepe - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 209
All Time: 41,697
