Up to 20% off select tools
Disassembling Macintosh IIsi Floppy Drive
Views: 3.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
79
All Time:
3,537
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Macintosh IIsi came with a red-ribbon 1.44MB "SuperDrive" (and yes, just like DVD-Burning "SuperDrives" this was the best available option)
    1. Disassembling Macintosh IIsi Floppy Drive, Top Case: step 1, image 1 of 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: step 1, image 2 of 2
      • Start by turning the computer around, and remove this #0 Phillips Screw.
      • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
      Ask FixBot
    2. Disassembling Macintosh IIsi Floppy Drive: step 2, image 1 of 3 Disassembling Macintosh IIsi Floppy Drive: step 2, image 2 of 3 Disassembling Macintosh IIsi Floppy Drive: step 2, image 3 of 3
      • Now lift these two clips, and slowly pivot the case up.
      • You can now seperate the top of the computer from the rest of the machine.
      Ask FixBot
    1. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: step 3, image 1 of 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: step 3, image 2 of 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: step 3, image 3 of 3
      • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
      • Push these two tabs out, and lift the drive up.
      Ask FixBot
    2. Disassembling Macintosh IIsi Floppy Drive: step 4, image 1 of 3 Disassembling Macintosh IIsi Floppy Drive: step 4, image 2 of 3 Disassembling Macintosh IIsi Floppy Drive: step 4, image 3 of 3
      • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
      • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
      • This drive was manufactured by Sony in 1990.
      Ask FixBot
2 other people completed this guide.
Author
with
Chris Green
38,466 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
1 Guide Comment
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 79
All Time: 3,537
