Up to 20% off select tools
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
Views: 9.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
136
All Time:
9,373
Comments: 16
9 comments on steps, 7 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to disassemble and remove the scroll wheel of the Logitech MBJ58 optical scroll mouse. This might be necessary if the wheel is stuck, difficult to turn, or dislodged. If it becomes dislodged, it can cause additional damage to the mouse’s motherboard, which is located beneath the wheel.
The scroll wheel may become jammed if the support spring that holds it in place is dislodged. To see how to repair that, as well as how to deconstruct other parts of the mouse, see the Logitech MBJ58 mouse troubleshooting guide.
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: step 1, image 1 of 1
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Ask FixBot
    2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 2, image 1 of 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 2, image 2 of 2
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Ask FixBot
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 1 of 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 2 of 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 3 of 3
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      Ask FixBot
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: step 4, image 1 of 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: step 4, image 2 of 2
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      Ask FixBot
    2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: step 5, image 1 of 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: step 5, image 2 of 2
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      Ask FixBot
    1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 6, image 1 of 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 6, image 2 of 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: step 6, image 3 of 3
      • Use the images to locate where the resistance spring is.
      • This spring will easily fall off.
      • Grab the scroll wheel and its mount and gently pull them apart.
      Ask FixBot
14 other people completed this guide.
Author
with
Maximilian Betkowski
238 Reputation
4 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
84 Guides authored
7 Guide Comments
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Reply Share
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Reply Share
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Reply Share
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Reply Share
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 136
All Time: 9,373
