Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections
    1. Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections, Interior Soldered Wire Connections: step 1, image 1 of 1
      • The back panel (pictured left) has a black wire (end of wire circled red). The wire solders to the bottom right corner of the card drive.
      • The front panel (pictured right) has a black and red wire (end of wired circled green). This wire solders to a small circular spot next to where the black wire connects to the back (from above).
      Ask FixBot
ewkpates
133 Reputation
1 Guide authored
2 Guide Comments
To open the leappad top start with, remove battery covers and the 6 screws.
The two halves slide, bottom half towards cartridge slot, to make it harder they have used double sided tape on the bottom platic tounges, so a scredriver in the bottom will be needed to prize the slide.
Lawrence - Reply Share
Good stuff. I'm trying to slide the back plate upward, but to no avail. You mentioned tape. Where exactly is it located?
John - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 42
All Time: 6,525
