Disassembling LG420G Entire Phone
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
113
All Time:
1,375
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 40 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
If you need to take apart your LG420G phone, follow this disassembly guide. This guide will prove helpful in accessing internal components and investigating potential problems your phone may be having.
Before starting, it is important to make sure that the phone is powered down. One thing to note is that some of the components are glued down at points of the disassembly so you may want to use a iOpener to loosen the glue and make the process easier.
It is also important that during the disassembly process, all parts are kept organized and together so that the phone can be reassembled later.
Tools
    1. Disassembling LG420G Entire Phone, Phone: step 1, image 1 of 1
      • Flip the phone over with the screen facing down.
      • Remove the cover and battery.
      Ask FixBot
    2. Disassembling LG420G Entire Phone: step 2, image 1 of 2 Disassembling LG420G Entire Phone: step 2, image 2 of 2
      • Apply light pressure to the area shown and pull out gently to remove the SIM card.
      Ask FixBot
    3. Disassembling LG420G Entire Phone: step 3, image 1 of 3 Disassembling LG420G Entire Phone: step 3, image 2 of 3 Disassembling LG420G Entire Phone: step 3, image 3 of 3
      • Using a Phillips #000 screwdriver, remove all six screws.
      Ask FixBot
    4. Disassembling LG420G Entire Phone: step 4, image 1 of 1
      • With your tweezers, gently pry around the sides to expose the circuitry.
      Ask FixBot
    5. Disassembling LG420G Entire Phone: step 5, image 1 of 1
      • Separate the plastic shells gently and place both now exposed pieces on the ground.
      Ask FixBot
    6. Disassembling LG420G Entire Phone: step 6, image 1 of 2 Disassembling LG420G Entire Phone: step 6, image 2 of 2
      • Remove the small parts gently with your fingers.
      Ask FixBot
    7. Disassembling LG420G Entire Phone: step 7, image 1 of 1
      • Remove the circuit board.
      Ask FixBot
    8. Disassembling LG420G Entire Phone: step 8, image 1 of 1
      • Gently push the keypad out of the phone frame.
      Ask FixBot
    9. Disassembling LG420G Entire Phone: step 9, image 1 of 2 Disassembling LG420G Entire Phone: step 9, image 2 of 2
      • With an opening tool, start opening the front face of the phone.
      Ask FixBot
    10. Disassembling LG420G Entire Phone: step 10, image 1 of 1
      • Gently remove the front cover to further expose electronics inside.
      Ask FixBot
    11. Disassembling LG420G Entire Phone: step 11, image 1 of 1
      • Gently pry apart glued layer.
      • Use an electronic safe adhesive remover to mitigate the risk of damage.
      Ask FixBot
    12. Disassembling LG420G Entire Phone: step 12, image 1 of 1
      • The completely disassembled phone should look similar to the picture shown.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 113
All Time: 1,375
