Up to 20% off select tools
Disassembling LG Vortex
Views: 5.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
44
All Time:
5,160
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The guide is designed specifically for the LG Vortex phone. This guide gives detailed instructions on the removal of the back case and the face from the frame.
    1. Disassembling LG Vortex, Power down the Phone: step 1, image 1 of 1
      • Power the phone off
      • The power button is located on top of the phone
      Ask FixBot
    2. Disassembling LG Vortex, Remove the Back Cover: step 2, image 1 of 3 Disassembling LG Vortex, Remove the Back Cover: step 2, image 2 of 3 Disassembling LG Vortex, Remove the Back Cover: step 2, image 3 of 3
      • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
      • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
      • Remove the back cover and set it to the side.
      Ask FixBot
    3. Disassembling LG Vortex: step 3, image 1 of 1
      • Remove the battery using the blue plastic opening tool.
      • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
      • Put the battery aside.
      Ask FixBot
    4. Disassembling LG Vortex, Unscrew the Back Frame: step 4, image 1 of 2 Disassembling LG Vortex, Unscrew the Back Frame: step 4, image 2 of 2
      • All screws are the same size screwdriver head #00
      • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
      • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
      • Place the screws in a container to ensure they aren't lost.
      Ask FixBot
    5. Disassembling LG Vortex, Remove the Back Frame: step 5, image 1 of 3 Disassembling LG Vortex, Remove the Back Frame: step 5, image 2 of 3 Disassembling LG Vortex, Remove the Back Frame: step 5, image 3 of 3
      • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
      • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
      • Pry your way around the entire phone to separate the face from the frame.
      Ask FixBot
3 other people completed this guide.
Author
with
Jen
40 Reputation
3 Guides authored
Ohio State, Team 1-3, Buehl Spring 2014 Member of Ohio State, Team 1-3, Buehl Spring 2014
OSU-BUEHL-S14S1G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 44
All Time: 5,160
