Up to 20% off select tools
Disassembling Konica Compact 8 Filmdoor
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
57
All Time:
304
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
You might want to remove the latchdoor to get better access to the DC micromotor.
    1. Disassembling Konica Compact 8 Filmdoor, The latch door: step 1, image 1 of 1
      • These 4 screws are all that holds the latchdoor connected to the body.
      • It also holds the metal that will keep the film cartridge in place. This is a seperate piece that lays underneath the latch.
      Ask FixBot
    2. Disassembling Konica Compact 8 Filmdoor, Preperation: step 2, image 1 of 2 Disassembling Konica Compact 8 Filmdoor, Preperation: step 2, image 2 of 2
      • Make sure that you lay a piece of cloth inside the empty film case, this to prevent loose screws to dissapear in the little hole that is located on the top left side.
      Ask FixBot
    3. Disassembling Konica Compact 8 Filmdoor, Unscrewing the screws: step 3, image 1 of 1
      • Now simply unscrew the 4 screws and the door should come off flawlessly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure the hinge-part is underneath the latchdoor, not on top of it!
Author
with
JonasB7
485 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 57
All Time: 304
