Disassembling Kodak Easyshare C813 Back Cover
    1. Disassembling Kodak Easyshare C813 Back Cover, Battery: step 1, image 1 of 1
      • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
      Ask FixBot
    2. Disassembling Kodak Easyshare C813 Back Cover: step 2, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 2, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 2, image 3 of 3
      • Press thumb firmly on battery door and slide it in the direction of the arrow.
      • Lift thumb allowing the door to swing open.
      Ask FixBot
    1. Disassembling Kodak Easyshare C813 Back Cover, Back Cover: step 3, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      Ask FixBot
    2. Disassembling Kodak Easyshare C813 Back Cover: step 4, image 1 of 1
      • Turn the camera off by firmly pressing the power button located on top of the camera.
      Ask FixBot
    3. Disassembling Kodak Easyshare C813 Back Cover: step 5, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 5, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 5, image 3 of 3
      • Locate the 7 screws holding the back cover on.
      • Three screws are located on the bottom of the camera.
      • Two screws are located on the side shown in the photograph.
      • Two final screws are located on the opposite side shown in the photograph.
      Ask FixBot
    4. Disassembling Kodak Easyshare C813 Back Cover: step 6, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 6, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 6, image 3 of 3
      • Remove all 7 screws:
      • Hold the camera firmly with one hand so that you can still see a screw.
      • Place the Philips 00(Found here)screwdriver into the screw.
      • Turn the screwdriver to the left until it is free.
      • Repeat for the remaining screws.
      Ask FixBot
    5. Disassembling Kodak Easyshare C813 Back Cover: step 7, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 7, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 7, image 3 of 3
      • Use plastic opening tools to slightly open the side of the case.
      • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
      • The first two are near the words "3X Optical Zoom".
      • The third is near the shutter button.
      Ask FixBot
    6. Disassembling Kodak Easyshare C813 Back Cover: step 8, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 8, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 8, image 3 of 3
      • Gently pull apart the back cover from the rest of the camera.
      • Make sure there are no more screws or tabs keeping the cover on.
      • Use the plastic opening tool to separate any sides still closely connected.
      Ask FixBot
Finish Line
Susan Marano
342 Reputation
7 Guides authored
Cal Poly, Team 24-22, Regan Spring 2010 Member of Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 45
All Time: 3,051
