Disassembling Kodak Advantix F350 Display
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
115
All Time:
2,020
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Outline what you are going to teach someone how to do.
Tools
    1. Disassembling Kodak Advantix F350 Display, Back Cover: step 1, image 1 of 1
      • Turn off the camera.
      • Locate the power switch on the front of the camera below the camera lens.
      • Slide the switch to the off position.
      Ask FixBot
    2. Disassembling Kodak Advantix F350 Display: step 2, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 2, image 2 of 2
      • Locate the 3 screws that hold the back cover to the camera.
      • One screw is located on the film opener side of the camera.
      • The other screws are located on the opposite side of the camera.
      Ask FixBot
    3. Disassembling Kodak Advantix F350 Display: step 3, image 1 of 3 Disassembling Kodak Advantix F350 Display: step 3, image 2 of 3 Disassembling Kodak Advantix F350 Display: step 3, image 3 of 3
      • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
      Ask FixBot
    4. Disassembling Kodak Advantix F350 Display: step 4, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 4, image 2 of 2
      • Open the film door to remove the back cover.
      • Slide the film door lever to the left until the film door opens.
      Ask FixBot
    5. Disassembling Kodak Advantix F350 Display: step 5, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 5, image 2 of 2
      • Use a plastic opening tool to pry the case open until a small gap is present.
      • Repeat this process at the top and bottom of the film door to loosen it.
      Ask FixBot
    6. Disassembling Kodak Advantix F350 Display: step 6, image 1 of 3 Disassembling Kodak Advantix F350 Display: step 6, image 2 of 3 Disassembling Kodak Advantix F350 Display: step 6, image 3 of 3
      • Grab the top and bottom of the case firmly as shown.
      • Gently remove the back of the camera case with a slight twisting motion.
      Ask FixBot
    1. Disassembling Kodak Advantix F350 Display, Front Cover: step 7, image 1 of 2 Disassembling Kodak Advantix F350 Display, Front Cover: step 7, image 2 of 2
      • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
      • The first 2 are located on the bottom of the camera.
      • The last screw is located behind the flash module.
      • Turn the camera on, and raise the flash module to locate the flash module screw.
      Ask FixBot
    2. Disassembling Kodak Advantix F350 Display: step 8, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 8, image 2 of 2
      • Remove the 2 screws at the base of the camera housing.
      • Use the Phillips #00 Precision Screwdriver and remove the screws.
      • Repeat this process for the screw behind the flash module.
      Ask FixBot
    3. Disassembling Kodak Advantix F350 Display: step 9, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 9, image 2 of 2
      • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
      Ask FixBot
    4. Disassembling Kodak Advantix F350 Display: step 10, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 10, image 2 of 2
      • Remove the flash cover.
      • Remove the flash module by twisting it up and outward of the camera housing.
      • The cover can now be be removed.
      Ask FixBot
    5. Disassembling Kodak Advantix F350 Display: step 11, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 11, image 2 of 2
      • Remove the film door lever.
      • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
      • Using a plastic opening tool, gently pry the switch upwards to remove it.
      Ask FixBot
    6. Disassembling Kodak Advantix F350 Display: step 12, image 1 of 1
      • Open the battery door by pushing the lever towards the arrow indicated.
      Ask FixBot
    7. Disassembling Kodak Advantix F350 Display: step 13, image 1 of 3 Disassembling Kodak Advantix F350 Display: step 13, image 2 of 3 Disassembling Kodak Advantix F350 Display: step 13, image 3 of 3
      • Remove the front cover.
      • Insert your thumb in the film hole and gently pry the bottom loose.
      • Once the front is loose, gently pull it out.
      Ask FixBot
    1. Disassembling Kodak Advantix F350 Display, Display: step 14, image 1 of 1
      • Locate the 3 screws on the top of the camera.
      • These will be removed in the next step.
      Ask FixBot
    2. Disassembling Kodak Advantix F350 Display: step 15, image 1 of 3 Disassembling Kodak Advantix F350 Display: step 15, image 2 of 3 Disassembling Kodak Advantix F350 Display: step 15, image 3 of 3
      • Remove the 3 screws using the Phillips #00 Precision Screwdriver.
      Ask FixBot
    3. Disassembling Kodak Advantix F350 Display: step 16, image 1 of 2 Disassembling Kodak Advantix F350 Display: step 16, image 2 of 2
      • Remove the LCD.
      • Gently pry the LCD and plastic bezel upward with a plastic opening tool.
      • Remove LCD and replace as needed.
      Ask FixBot
David Cottrell
103 Reputation
5 Guides authored
UW Stout, Team 1-2, Zhou Fall 2011 Member of UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 115
All Time: 2,020
