Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: step 1, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: step 1, image 2 of 2
    • Using a spudger, gently pry off the aluminum drip ring.
    Ask FixBot
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 2, image 1 of 1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
    Ask FixBot
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 3, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 3, image 2 of 2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
    Ask FixBot
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 4, image 1 of 1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
    Ask FixBot
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 5, image 1 of 1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
    Ask FixBot
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 6, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 6, image 2 of 2
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
    Ask FixBot
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 7, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 7, image 2 of 2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
    Ask FixBot
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 8, image 1 of 1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
    Ask FixBot
42 other people completed this guide.
Chris Gonzales
1,665 Reputation
2 Guides authored
Cal Poly, Team 14-28, Maness Fall 2014 Member of Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 Members
22 Guides authored
27 Guide Comments
Well fine job! Just finished and t works!!!
James Anderson - Reply Share
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Aristides Aleman - Reply Share
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Heather Schrader - Reply Share
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Royce M - Reply Share
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
Ariel Cornejo - Reply Share
Past 24 Hours: 19
Past 7 Days: 179
Past 30 Days: 849
All Time: 129,204
