Disassembling KDDI Kyocera A5521K Camera
  1. Disassembling KDDI Kyocera A5521K Camera, Faceplate: step 1, image 1 of 3 Disassembling KDDI Kyocera A5521K Camera, Faceplate: step 1, image 2 of 3 Disassembling KDDI Kyocera A5521K Camera, Faceplate: step 1, image 3 of 3
    • Start by prying, with a metal probe, the black covers that are located by the pivoting joints of the phone/
    • Beneath those covers are the screws.
    Ask FixBot
  2. Disassembling KDDI Kyocera A5521K Camera: step 2, image 1 of 1
    • Remove the screws using a Y0 screwdriver.
    Ask FixBot
  3. Disassembling KDDI Kyocera A5521K Camera: step 3, image 1 of 3 Disassembling KDDI Kyocera A5521K Camera: step 3, image 2 of 3 Disassembling KDDI Kyocera A5521K Camera: step 3, image 3 of 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It adheres strongly to the phone.
    Ask FixBot
  4. Disassembling KDDI Kyocera A5521K Camera: step 4, image 1 of 1
    • Use the Y0 screwdriver to remove the screws.
    Ask FixBot
  5. Disassembling KDDI Kyocera A5521K Camera: step 5, image 1 of 2 Disassembling KDDI Kyocera A5521K Camera: step 5, image 2 of 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
    Ask FixBot
  6. Disassembling KDDI Kyocera A5521K Camera: step 6, image 1 of 3 Disassembling KDDI Kyocera A5521K Camera: step 6, image 2 of 3 Disassembling KDDI Kyocera A5521K Camera: step 6, image 3 of 3
    • Separate the faceplate from the phone.
    Ask FixBot
  7. Disassembling KDDI Kyocera A5521K Camera, Camera: step 7, image 1 of 2 Disassembling KDDI Kyocera A5521K Camera, Camera: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip).
    Ask FixBot
  8. Disassembling KDDI Kyocera A5521K Camera: step 8, image 1 of 3 Disassembling KDDI Kyocera A5521K Camera: step 8, image 2 of 3 Disassembling KDDI Kyocera A5521K Camera: step 8, image 3 of 3
    • Carefully pry up the camera unit with a spudger.
    • Be careful not to damage the camera unit.
    • The camera should now be separated from the phone.
    Ask FixBot
Dominic Grisafe
157 Reputation
10 Guides authored
Cal Poly, Team 28-25, Regan Spring 2010 Member of Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Members
34 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,777
