Disassembling KDDI Kyocera A5521K Back Plate
    1. Disassembling KDDI Kyocera A5521K Back Plate, Battery: step 1, image 1 of 3 Disassembling KDDI Kyocera A5521K Back Plate, Battery: step 1, image 2 of 3 Disassembling KDDI Kyocera A5521K Back Plate, Battery: step 1, image 3 of 3
      • Turn the phone over to expose the battery cover.
      • Apply pressure to the back of the battery cover to slide it down.
      • The battery cover is now separate from the phone.
      Ask FixBot
    2. Disassembling KDDI Kyocera A5521K Back Plate: step 2, image 1 of 3 Disassembling KDDI Kyocera A5521K Back Plate: step 2, image 2 of 3 Disassembling KDDI Kyocera A5521K Back Plate: step 2, image 3 of 3
      • Remove the battery by pushing it up and out from the bottom.
      • The battery, cover, and phone should now be separated.
      Ask FixBot
    1. Disassembling KDDI Kyocera A5521K Back Plate, Back Plate: step 3, image 1 of 2 Disassembling KDDI Kyocera A5521K Back Plate, Back Plate: step 3, image 2 of 2
      • Remove the four screws with the Y0 screwdriver.
      Ask FixBot
    2. Disassembling KDDI Kyocera A5521K Back Plate: step 4, image 1 of 2 Disassembling KDDI Kyocera A5521K Back Plate: step 4, image 2 of 2
      • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
      • Remove the two screws with a Y0 screwdriver.
      Ask FixBot
    3. Disassembling KDDI Kyocera A5521K Back Plate: step 5, image 1 of 3 Disassembling KDDI Kyocera A5521K Back Plate: step 5, image 2 of 3 Disassembling KDDI Kyocera A5521K Back Plate: step 5, image 3 of 3
      • Rotate the phone 180 degrees.
      • Carefully separate the back plate from the remainder of the phone.
      • The back plate should now be detached from the rest of the phone.
      Ask FixBot
2 other people completed this guide.
Dominic Grisafe
157 Reputation
10 Guides authored
Cal Poly, Team 28-25, Regan Spring 2010 Member of Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 37
All Time: 3,199
