Up to 20% off select tools
Disassembling JBL Spyro subwoofer
View statistics:
Past 24 Hours:
2
Past 7 Days:
7
Past 30 Days:
25
All Time:
25
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Community-Contributed Guide
    1. Disassembling JBL Spyro subwoofer, Step 1: Remove the bottom panel: step 1, image 1 of 2 Disassembling JBL Spyro subwoofer, Step 1: Remove the bottom panel: step 1, image 2 of 2
      • The bottom panel is held in place by three pins; there are no screws. Insert a screwdriver and carefully pry the panel off.
      Ask FixBot
    2. Disassembling JBL Spyro subwoofer, Step 2: Remove the first ring-shaped panel: step 2, image 1 of 3 Disassembling JBL Spyro subwoofer, Step 2: Remove the first ring-shaped panel: step 2, image 2 of 3 Disassembling JBL Spyro subwoofer, Step 2: Remove the first ring-shaped panel: step 2, image 3 of 3
      • Do not remove the four large screws yet. They hold the speaker in place. Removing them now will make disassembly more difficult and could damage the speaker or tear its wires.
      • Remove the six screws holding the next panel, then lift off the ring-shaped panel.
      Ask FixBot
    3. Disassembling JBL Spyro subwoofer, Step 3: Remove the ring-shaped panel with a cutout: step 3, image 1 of 2 Disassembling JBL Spyro subwoofer, Step 3: Remove the ring-shaped panel with a cutout: step 3, image 2 of 2
      • Remove the six screws, then lift off the ring-shaped panel with a cutout
      Ask FixBot
    4. Disassembling JBL Spyro subwoofer, Step 4: Remove the next ring-shaped panel: step 4, image 1 of 2 Disassembling JBL Spyro subwoofer, Step 4: Remove the next ring-shaped panel: step 4, image 2 of 2
      • Remove another six screws, then lift off the ring-shaped panel.
      Ask FixBot
    5. Disassembling JBL Spyro subwoofer, Step 5: Remove the housing screws: step 5, image 1 of 1
      • Remove the five screws holding the housing.
      Ask FixBot
    6. Disassembling JBL Spyro subwoofer, Step 6: Release the clips and remove the housing: step 6, image 1 of 3 Disassembling JBL Spyro subwoofer, Step 6: Release the clips and remove the housing: step 6, image 2 of 3 Disassembling JBL Spyro subwoofer, Step 6: Release the clips and remove the housing: step 6, image 3 of 3
      • Release the clips and lift off the housing.
      • Now, to replace or repair it, you need to remove the speaker.
      • The speaker is located beneath the curved yellow tube. The tube is glued and screwed to the bottom of the housing. I do not recommend removing it because it could crack the tube or the housing.
      Ask FixBot
    7. Disassembling JBL Spyro subwoofer, Step 7: Remove the electronic board: step 7, image 1 of 2 Disassembling JBL Spyro subwoofer, Step 7: Remove the electronic board: step 7, image 2 of 2
      • Remove the two screws holding the electronic board, then take the board out of the way.
      Ask FixBot
    8. Disassembling JBL Spyro subwoofer, Step 8: Remove the speaker: step 8, image 1 of 1
      • Carefully disconnect the wires running from the speaker. Remove the four screws holding the speaker, then lift it out.
      Ask FixBot
    9. Disassembling JBL Spyro subwoofer, Step 9: Remove the old surround and adhesive: step 9, image 1 of 1
      • Remove the remaining pieces of the old surround and adhesive from the cone and plastic frame. I used an engraving knife.
      Ask FixBot
    10. Disassembling JBL Spyro subwoofer, Step 10: Prepare the surfaces and choose a replacement surround: step 10, image 1 of 1
      • Remove all remaining adhesive and surround material. The speaker should look like the one shown in the photo.
      • There are two common types of replacement surround: rubber and foam. I chose a rubber surround because foam can deteriorate quickly in hot, humid climates.
      • Before gluing, thoroughly degrease the surfaces with alcohol. Do not use gasoline or acetone.
      Ask FixBot
    11. Disassembling JBL Spyro subwoofer, Step 11: Attach the surround to the cone: step 11, image 1 of 1
      • Temporarily hold the rubber surround to the speaker frame with binder clips. Then glue the surround to the cone.
      Ask FixBot
    12. Disassembling JBL Spyro subwoofer, Step 12: Center the cone: step 12, image 1 of 1
      • Before gluing the surround to the speaker frame, center the cone. If it is off-center, the speaker may scrape or make a rustling sound during playback.
      • Remove the binder clips and gently move the cone up and down and in different directions. Adjust it until you hear no scraping or rubbing.
      Ask FixBot
    13. Disassembling JBL Spyro subwoofer, Step 13: Glue the surround to the frame: step 13, image 1 of 1
      • Once the cone is centered, glue the surround to the speaker frame.
      • The position of the center is fixed with binders
      Ask FixBot
    14. Disassembling JBL Spyro subwoofer, Step 14: Test the speaker: step 14, image 1 of 1
      • Reconnect the speaker and place it temporarily on the housing. Play some music to check that it works properly.
      Ask FixBot
    15. Disassembling JBL Spyro subwoofer, Step 15: Reinstall the speaker: step 15, image 1 of 2 Disassembling JBL Spyro subwoofer, Step 15: Reinstall the speaker: step 15, image 2 of 2
      • Put the speaker back in place and secure it with its four screws.
      Ask FixBot
    16. Disassembling JBL Spyro subwoofer, Step 16: Reassemble the subwoofe: step 16, image 1 of 2 Disassembling JBL Spyro subwoofer, Step 16: Reassemble the subwoofe: step 16, image 2 of 2
      • Reassemble the subwoofer by following the disassembly steps in reverse order.
      Ask FixBot
    17. Disassembling JBL Spyro subwoofer, Note: step 17, image 1 of 1
      • The spider (the inner suspension beneath the cone) had also crumbled. I did not replace it. On this speaker, the voice coil is long enough to remain in place during operation.
      • Good luck with your repair!
      Ask FixBot
    18. Disassembling JBL Spyro subwoofer, What is required and what is prohibited: step 18, image 1 of 3 Disassembling JBL Spyro subwoofer, What is required and what is prohibited: step 18, image 2 of 3 Disassembling JBL Spyro subwoofer, What is required and what is prohibited: step 18, image 3 of 3
      • I used a rubber surround and glue.
      • Zhanlinda glue does not bond rubber or plastic.
      Ask FixBot
Alexander Efremov
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 25
All Time: 25
