Disassembling Insignia NS-B2110 Bottom Panel
    1. Disassembling Insignia NS-B2110 Bottom Panel, Battery: step 1, image 1 of 2 Disassembling Insignia NS-B2110 Bottom Panel, Battery: step 1, image 2 of 2
      • Flip the stereo so the CD opening is face down.
      • With two fingers, pinch the tabs and lift up to open the battery protection cover.
      Ask FixBot
    2. Disassembling Insignia NS-B2110 Bottom Panel: step 2, image 1 of 2 Disassembling Insignia NS-B2110 Bottom Panel: step 2, image 2 of 2
      • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
      • Repeat until all eight batteries are removed.
      • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
      Ask FixBot
    1. Disassembling Insignia NS-B2110 Bottom Panel, Bottom Panel: step 3, image 1 of 1
      • With a Phillips #2 screwdriver, remove two 2mm screws.
      Ask FixBot
    2. Disassembling Insignia NS-B2110 Bottom Panel: step 4, image 1 of 2 Disassembling Insignia NS-B2110 Bottom Panel: step 4, image 2 of 2
      • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
      • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
      Ask FixBot
    3. Disassembling Insignia NS-B2110 Bottom Panel: step 5, image 1 of 3 Disassembling Insignia NS-B2110 Bottom Panel: step 5, image 2 of 3 Disassembling Insignia NS-B2110 Bottom Panel: step 5, image 3 of 3
      • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
      • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
      • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
      Ask FixBot
Nikki
104 Reputation
1 Guide authored
Cal Poly, Team 4-31, Amido Fall 2013 Member of Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 19
All Time: 565
