Disassembling Insignia Flex 8 Circuit Board
    1. Disassembling Insignia Flex 8 Circuit Board, Circuit Board: step 1, image 1 of 1
      • Turn off the power to your tablet to avoid injury.
      • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
      • Hold down the power button for five seconds until the tablet powers down.
      Ask FixBot
    2. Disassembling Insignia Flex 8 Circuit Board: step 2, image 1 of 2 Disassembling Insignia Flex 8 Circuit Board: step 2, image 2 of 2
      • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • You may need to use a spudger to initially create separation between the screen and the casing.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      Ask FixBot
    3. Disassembling Insignia Flex 8 Circuit Board: step 3, image 1 of 2 Disassembling Insignia Flex 8 Circuit Board: step 3, image 2 of 2
      • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
      Ask FixBot
    4. Disassembling Insignia Flex 8 Circuit Board: step 4, image 1 of 3 Disassembling Insignia Flex 8 Circuit Board: step 4, image 2 of 3 Disassembling Insignia Flex 8 Circuit Board: step 4, image 3 of 3
      • To remove the camera ribbon cable, lift the flap using a spudger.
      • Pull the ribbon directly back to release it.
      Ask FixBot
    5. Disassembling Insignia Flex 8 Circuit Board: step 5, image 1 of 3 Disassembling Insignia Flex 8 Circuit Board: step 5, image 2 of 3 Disassembling Insignia Flex 8 Circuit Board: step 5, image 3 of 3
      • Remove the second ribbon cable by prying up the black flap using a spudger.
      • Pull the ribbon cable horizontally directly away from the battery.
      Ask FixBot
    6. Disassembling Insignia Flex 8 Circuit Board: step 6, image 1 of 3 Disassembling Insignia Flex 8 Circuit Board: step 6, image 2 of 3 Disassembling Insignia Flex 8 Circuit Board: step 6, image 3 of 3
      • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
      • Pull the ribbon horizontally directly away from the battery.
      Ask FixBot
    7. Disassembling Insignia Flex 8 Circuit Board: step 7, image 1 of 2 Disassembling Insignia Flex 8 Circuit Board: step 7, image 2 of 2
      • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
      Ask FixBot
    8. Disassembling Insignia Flex 8 Circuit Board: step 8, image 1 of 2 Disassembling Insignia Flex 8 Circuit Board: step 8, image 2 of 2
      • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
      • Lift up the circuit board.
      Ask FixBot
    9. Disassembling Insignia Flex 8 Circuit Board: step 9, image 1 of 1
      • Unscrew the final two screws that were underneath the circuit board.
      • These screws are near the charging port and USB adapter.
      • These screws are also 3.75mm and can be interchanged with the second set of screws only.
      Ask FixBot
    10. Disassembling Insignia Flex 8 Circuit Board: step 10, image 1 of 1
      • Lift the circuit board and black internal mounting piece away from the screen.
      • Set the circuit board aside.
      • Be careful of the soldered antenna as you separate the pieces.
      • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
      Ask FixBot
2 other people completed this guide.
Tyler Tyrrell
890 Reputation
4 Guides authored
2 Guide Comments
Whwre can i buy the new screen
Emmanuel - Reply Share
I don’t see the ssd, and way to upgrade the internal sad had?
William Henderson - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 61
All Time: 5,365
