Up to 20% off select tools
Disassembling IBM WorkPad c3 Back Case
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
98
All Time:
2,211
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 45 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will explain step by step how to remove the outer cases of the IBM WorkPad c3.
    1. Disassembling IBM WorkPad c3 Back Case, Back Case: step 1, image 1 of 2 Disassembling IBM WorkPad c3 Back Case, Back Case: step 1, image 2 of 2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      Ask FixBot
    2. Disassembling IBM WorkPad c3 Back Case: step 2, image 1 of 1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      Ask FixBot
    3. Disassembling IBM WorkPad c3 Back Case: step 3, image 1 of 2 Disassembling IBM WorkPad c3 Back Case: step 3, image 2 of 2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      Ask FixBot
Author
with
Emily Falkenstein
75 Reputation
5 Guides authored
Cal Poly, Team 21-35, Regan Fall 2010 Member of Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 98
All Time: 2,211
