Up to 20% off select tools
Disassembling IBM ThinkPad T42 Rear Cover
Views: 4.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
43
All Time:
4,853
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
The device we are working is a IBM ThinkPad T42 and disassembly the rear cover. This is a simple dissemble but requires the removal of a lot of screws so it could get tricky to return all correct screws to their respectful place. The rear cover is a simple removal that may be needed if we might want to replace parts of the ThinkPad or get into the hardware in ThinkPad to make a more complex repair but want to know what to unscrew from device first. Having a guide to some repairs is necessary to not screw it wrong or get all mixed up by using a side-by-side guide to get a reference to what you need to do.
    1. Disassembling IBM ThinkPad T42 Rear Cover, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. Disassembling IBM ThinkPad T42 Rear Cover, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
Author
with
Gerald Watanabe
288 Reputation
7 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 43
All Time: 4,853
