Disassembling IBM ThinkPad T42 Plastic Edge Cover
    1. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Bottom cover: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
      Ask FixBot
    2. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Rear screws: step 2, image 1 of 1
      • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
      Ask FixBot
    1. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Keyboard and Trackpad: step 3, image 1 of 1
      • Flip the laptop over and open the screen to access the keyboard and trackpad.
      • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
      • The bezel and keyboard will be loose, be careful.
      Ask FixBot
    2. Disassembling IBM ThinkPad T42 Plastic Edge Cover: step 4, image 1 of 2 Disassembling IBM ThinkPad T42 Plastic Edge Cover: step 4, image 2 of 2
      • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
      Ask FixBot
    1. Disassembling IBM ThinkPad T42 Plastic Edge Cover, Plastic Edge Cover: step 5, image 1 of 2 Disassembling IBM ThinkPad T42 Plastic Edge Cover, Plastic Edge Cover: step 5, image 2 of 2
      • Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
      Ask FixBot
Gerald Watanabe
288 Reputation
7 Guides authored
Cal Poly, Team 29-76, Johann Spring 2010 Member of Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 25
All Time: 7,399
