Up to 20% off select tools
Disassembling IBM ThinkPad A30 Upper Case
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
95
All Time:
2,957
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the ThinkPad's upper case.
    1. Disassembling IBM ThinkPad A30 Upper Case, Battery: step 1, image 1 of 2 Disassembling IBM ThinkPad A30 Upper Case, Battery: step 1, image 2 of 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Ask FixBot
    1. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: step 2, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: step 2, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: step 2, image 3 of 3
      • Remove the highlighted screw with a Phillips #1 screwdriver.
      • Pull the hard drive out.
      Ask FixBot
    1. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: step 3, image 1 of 1
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
      Ask FixBot
    2. Disassembling IBM ThinkPad A30 Upper Case: step 4, image 1 of 1
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
      Ask FixBot
    3. Disassembling IBM ThinkPad A30 Upper Case: step 5, image 1 of 2 Disassembling IBM ThinkPad A30 Upper Case: step 5, image 2 of 2
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
      Ask FixBot
    4. Disassembling IBM ThinkPad A30 Upper Case: step 6, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 6, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 6, image 3 of 3
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
      Ask FixBot
    5. Disassembling IBM ThinkPad A30 Upper Case: step 7, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 7, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 7, image 3 of 3
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
      Ask FixBot
    6. Disassembling IBM ThinkPad A30 Upper Case: step 8, image 1 of 2 Disassembling IBM ThinkPad A30 Upper Case: step 8, image 2 of 2
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
      Ask FixBot
    7. Disassembling IBM ThinkPad A30 Upper Case: step 9, image 1 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 9, image 2 of 3 Disassembling IBM ThinkPad A30 Upper Case: step 9, image 3 of 3
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
      Ask FixBot
Author
with
Alan
380 Reputation
6 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 95
All Time: 2,957
