Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
    1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: step 1, image 1 of 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: step 1, image 2 of 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Ask FixBot
    1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: step 2, image 1 of 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: step 2, image 2 of 2
      • Remove the two 5.3mm cover screws.
      • Gently lift the cover.
      Ask FixBot
    2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 3, image 1 of 1
      • Remove the four 9.1mm screws attached to the ethernet and modem cards.
      Ask FixBot
    3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 4, image 1 of 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 4, image 2 of 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: step 4, image 3 of 3
      • When lifting the cards, be careful not to rip out the cables!
      • Gently lift the modem and ethernet cards.
      • Remove the cables that attach the modem and ethernet cards.
      Ask FixBot
Alan
380 Reputation
6 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
155 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 2,393
