Disassembling Home Stereo and Theater Philips MCD288
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: step 1, image 1 of 1
    • remove the 4 screws on the bottem of the main set
    Ask FixBot
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: step 2, image 1 of 1
    • Lift the aluminium pane at both sides with a spudger.
    Ask FixBot
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: step 3, image 1 of 1
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
    Ask FixBot
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: step 4, image 1 of 2 Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: step 4, image 2 of 2
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
    Ask FixBot
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: step 5, image 1 of 2 Disassembling Home Stereo and Theater Philips MCD288, The inside: step 5, image 2 of 2
    • These pictures show the latches on each edge and on the top of the set.
    Ask FixBot
3 other people completed this guide.
Philipp
95 Reputation
1 Guide authored
1 Guide Comment
Tenho um mini system Toshiba não alimentação elétrica
Leolionel Colombiano - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 124
All Time: 9,711
