Up to 20% off select tools
Disassembling HTC One V Back Case
Views: 3.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
87
All Time:
3,910
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your back case is scratched or cracked, replacing your back case might be your best option. A new one can be installed using this guide.
    1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
      • Power off your device.
      • Remove the bottom cover by sliding it off.
      Ask FixBot
    2. Disassembling HTC One V Back Case: step 2, image 1 of 1
      • Remove the SIM card.
      • Remove the four screws securing the bottom casing.
      • Two 3.0 mm Phillips #0 screws in the top left and right corners.
      • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
      Ask FixBot
    3. Disassembling HTC One V Back Case: step 3, image 1 of 2 Disassembling HTC One V Back Case: step 3, image 2 of 2
      • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
      Ask FixBot
    4. Disassembling HTC One V Back Case: step 4, image 1 of 3 Disassembling HTC One V Back Case: step 4, image 2 of 3 Disassembling HTC One V Back Case: step 4, image 3 of 3
      • Use a plastic opening tool to pry open the bottom casing.
      • Remove the bottom casing by pulling it towards you.
      Ask FixBot
    1. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: step 5, image 1 of 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: step 5, image 2 of 3 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: step 5, image 3 of 3
      • Use the plastic opening tool to pry open the rear camera panel.
      • Remove both screws that are securing the back case.
      • One 4.0 mm Phillips #0 screw.
      • One 3.0 mm Phillips #0 screw.
      Ask FixBot
    2. Disassembling HTC One V Back Case: step 6, image 1 of 3 Disassembling HTC One V Back Case: step 6, image 2 of 3 Disassembling HTC One V Back Case: step 6, image 3 of 3
      • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
      • Pry from right to left to avoid potential damages to the ribbon.
      Ask FixBot
    3. Disassembling HTC One V Back Case: step 7, image 1 of 3 Disassembling HTC One V Back Case: step 7, image 2 of 3 Disassembling HTC One V Back Case: step 7, image 3 of 3
      • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
      • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
      Ask FixBot
3 other people completed this guide.
Author
with
Michael Lucido
852 Reputation
6 Guides authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 87
All Time: 3,910
