Disassembling HP Photosmart D110a Printer Hood
    1. Disassembling HP Photosmart D110a Printer Hood, Printer Hood Assembly: step 1, image 1 of 1
      • Pull down both front panels to open the printer. Lift the scanner flap upward by pulling down on it; there are two mouth pieces that need to be pulled down.
      • Adjust the flap covering the scanner upward, as shown.
      Ask FixBot
    2. Disassembling HP Photosmart D110a Printer Hood: step 2, image 1 of 1
      • Pull the scanner flap gently away from the printer to release its two clips.
      Ask FixBot
    3. Disassembling HP Photosmart D110a Printer Hood: step 3, image 1 of 1
      • Locate the three screws on top of the printer.
      • The orange circle shows a fourth screw located behind the power panel. Ignore this one for now, as directions to remove this screw are in Step 5.
      Ask FixBot
    4. Disassembling HP Photosmart D110a Printer Hood: step 4, image 1 of 3 Disassembling HP Photosmart D110a Printer Hood: step 4, image 2 of 3 Disassembling HP Photosmart D110a Printer Hood: step 4, image 3 of 3
      • Using a T-9 screwdriver, remove the three screws from the printer's top.
      Ask FixBot
    5. Disassembling HP Photosmart D110a Printer Hood: step 5, image 1 of 2 Disassembling HP Photosmart D110a Printer Hood: step 5, image 2 of 2
      • To remove the power button panel:
      • Reach inside the printer's front opening.
      • Press the small clip behind the power button.
      • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
      • Pull the panel out from right to left.
      Ask FixBot
    6. Disassembling HP Photosmart D110a Printer Hood: step 6, image 1 of 2 Disassembling HP Photosmart D110a Printer Hood: step 6, image 2 of 2
      • Remove the fourth screw, which was covered by the power button panel.
      • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
      • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
      Ask FixBot
    7. Disassembling HP Photosmart D110a Printer Hood: step 7, image 1 of 3 Disassembling HP Photosmart D110a Printer Hood: step 7, image 2 of 3 Disassembling HP Photosmart D110a Printer Hood: step 7, image 3 of 3
      • With a partner's help:
      • Have one person lift the hood 2-3 inches.
      • Have the other person disconnect the three cables from the motherboard (the green PCB) to the hood by gently pulling upward on them.
      • Remove the hood completely.
      Ask FixBot
    1. Disassembling HP Photosmart D110a Printer Hood, Printer Hood: step 8, image 1 of 3 Disassembling HP Photosmart D110a Printer Hood, Printer Hood: step 8, image 2 of 3 Disassembling HP Photosmart D110a Printer Hood, Printer Hood: step 8, image 3 of 3
      • Remove the single T-9 screw from the hood's underside, as shown.
      Ask FixBot
    2. Disassembling HP Photosmart D110a Printer Hood: step 9, image 1 of 2 Disassembling HP Photosmart D110a Printer Hood: step 9, image 2 of 2
      • With the screw removed, separate the two pieces of the hood by lifting it vertically.
      • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
      • Carefully pull down the white ribbon cable through the top piece of the hood.
      Ask FixBot
    3. Disassembling HP Photosmart D110a Printer Hood: step 10, image 1 of 2 Disassembling HP Photosmart D110a Printer Hood: step 10, image 2 of 2
      • Separate the hood pieces while keeping the black ribbon cable connected. Rest the scanner piece carefully to avoid stressing its ribbon cable.
      Ask FixBot
19 other people completed this guide.
Joseph Camilleri
237 Reputation
1 Guide authored
Cal Poly, Team 10-38, Forte Spring 2011 Member of Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Members
120 Guides authored
9 Guide Comments
Thanks for this guide. I never would have found that fourth screw without this guide. The illustration of the "clip" for removal of the power quadrant face could have been more detailed and/or you could have said in the description, "Feel for the TAB on the right center of the power button quadrant behind the "cartridge door open" feeler and push it toward the outside of the printer". Other than that, this was great.
Just A Mechanic - Reply Share
Hi Joseph,
Thanks for the guide. Very easy to follow. Saved me some dollars.
joenovelo - Reply Share
Great Support,.!!!
I am a handy person and a Computer tech for family and friends,.
Some time You just need Instruction on how to do do things, Other wise You taking the risks of braking things instead of fixing them
Thanks Guys
Milton Portillo - Reply Share
Thank you for posting this. In place of the pliers, I recommend using a small reversible ratchet offset (mine was 3-1/4"W x 6-3/4"L x 1/2"H) to remove the 4th screw. It won't slide of the screw like pliers and will make both the removal and replacement much easier.
theratchet - Reply Share
Where can I find spare parts for HP PSC photosmart D110?
Regards
Carlos Ahumada - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 107
All Time: 22,197
