Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case
  1. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case, Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: step 1, image 1 of 1
    • Unplug the toaster from the electrical outlet.
    Ask FixBot
  2. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: step 2, image 1 of 2 Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: step 2, image 2 of 2
    • Remove the two levers and four dials by pulling them out directly towards you.
    • Removing these components may require some force, but they will release.
    Ask FixBot
  3. Disassembling General Electric Bagel Switch 4-Slice Toaster Outer Case: step 3, image 1 of 1
    • Look for the plastic clips on the back side of the toaster.
    • Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
    • Now, carefully remove the toaster casing.
    Ask FixBot
Ron Gajdos
307 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 48
All Time: 1,564
