Disassembling Garmin Nuvi 1200 Logic Board
  1. Disassembling Garmin Nuvi 1200 Logic Board, Logic Board: step 1, image 1 of 1
    • Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
    • Once the tool is inserted it can slide around the entire device.
    Ask FixBot
  2. Disassembling Garmin Nuvi 1200 Logic Board: step 2, image 1 of 1
    • Remove four small T5 torx screws.
    • Be gentle, the screws are easily stripped.
    Ask FixBot
  3. Disassembling Garmin Nuvi 1200 Logic Board: step 3, image 1 of 2 Disassembling Garmin Nuvi 1200 Logic Board: step 3, image 2 of 2
    • Lift cover off of unit.
    • Be careful not to lose small rubber piece on the bottom right corner.
    Ask FixBot
  4. Disassembling Garmin Nuvi 1200 Logic Board: step 4, image 1 of 1
    • Disconnect ribbon cable from logic board.
    Ask FixBot
  5. Disassembling Garmin Nuvi 1200 Logic Board: step 5, image 1 of 1
    • Remove two T5 torx screws holding down logic board.
    • Disconnect battery.
    Ask FixBot
  6. Disassembling Garmin Nuvi 1200 Logic Board: step 6, image 1 of 1
    • Gently lift the logic board out of the unit
    • Be careful not to damage the battery connector on the top of the unit.
    Ask FixBot
6 other people completed this guide.
Zachary Landau
206 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 52
All Time: 5,561
