Up to 20% off select tools
Disassembling GD Midea FT30-3D Bottom Base
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
92
All Time:
1,305
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling GD Midea FT30-3D Bottom Base, Bottom Base: step 1, image 1 of 1
      • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
      Ask FixBot
    2. Disassembling GD Midea FT30-3D Bottom Base: step 2, image 1 of 2 Disassembling GD Midea FT30-3D Bottom Base: step 2, image 2 of 2
      • Locate the gray base support release tabs found on either side pictured in the first image.
      • There are release tabs on each side of the base.
      • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
      Ask FixBot
    3. Disassembling GD Midea FT30-3D Bottom Base: step 3, image 1 of 1
      • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
      • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
      Ask FixBot
    4. Disassembling GD Midea FT30-3D Bottom Base: step 4, image 1 of 1
      • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
      Ask FixBot
    5. Disassembling GD Midea FT30-3D Bottom Base: step 5, image 1 of 1
      • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
      • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
      Ask FixBot
    6. Disassembling GD Midea FT30-3D Bottom Base: step 6, image 1 of 1
      • Once all five screws have been removed the base cover should fall right off with out any effort.
      • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
      Ask FixBot
Author
with
Chris Hartley
450 Reputation
3 Guides authored
Cal Poly, Team 24-28, Regan Fall 2012 Member of Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 92
All Time: 1,305
