Disassembling Fujifilm Endeavor 100ix Outer Casing
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: step 1, image 1 of 1
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
    Ask FixBot
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 2, image 1 of 1
    • Locate the battery door.
    Ask FixBot
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 3, image 1 of 1
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
    Ask FixBot
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 4, image 1 of 1
    • Remove the battery from the camera by pulling the battery door outwards.
    Ask FixBot
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 5, image 1 of 1
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
    Ask FixBot
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 6, image 1 of 2 Disassembling Fujifilm Endeavor 100ix Outer Casing: step 6, image 2 of 2
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
    Ask FixBot
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 7, image 1 of 1
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
    Ask FixBot
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 8, image 1 of 1
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
    Ask FixBot
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 9, image 1 of 1
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
    Ask FixBot
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 10, image 1 of 1
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
    Ask FixBot
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: step 11, image 1 of 2 Disassembling Fujifilm Endeavor 100ix Outer Casing: step 11, image 2 of 2
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
    Ask FixBot
Eric Nicolai
679 Reputation
6 Guides authored
Cal Poly, Team 13-5, Forte Winter 2011 Member of Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 52
All Time: 1,701
