Up to 20% off select tools
Disassembling Flip Video Outer Shell
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
87
All Time:
2,827
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to open the outer shell of your Flip Video.
    1. Disassembling Flip Video Outer Shell, Outer Shell: step 1, image 1 of 2 Disassembling Flip Video Outer Shell, Outer Shell: step 1, image 2 of 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Ask FixBot
    2. Disassembling Flip Video Outer Shell: step 2, image 1 of 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Ask FixBot
    3. Disassembling Flip Video Outer Shell: step 3, image 1 of 2 Disassembling Flip Video Outer Shell: step 3, image 2 of 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Ask FixBot
    4. Disassembling Flip Video Outer Shell: step 4, image 1 of 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Ask FixBot
    5. Disassembling Flip Video Outer Shell: step 5, image 1 of 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Ask FixBot
Author
with
Elizabeth
100 Reputation
6 Guides authored
Cal Poly, Team 26-21, Regan Spring 2010 Member of Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 2,827
