Up to 20% off select tools
Disassembling Flip Video Circuit Board
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
90
All Time:
3,065
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to open your Flip Video and remove the main circuit board.
    1. Disassembling Flip Video Circuit Board, Outer Shell: step 1, image 1 of 2 Disassembling Flip Video Circuit Board, Outer Shell: step 1, image 2 of 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Ask FixBot
    2. Disassembling Flip Video Circuit Board: step 2, image 1 of 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Ask FixBot
    3. Disassembling Flip Video Circuit Board: step 3, image 1 of 2 Disassembling Flip Video Circuit Board: step 3, image 2 of 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Ask FixBot
    4. Disassembling Flip Video Circuit Board: step 4, image 1 of 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Ask FixBot
    5. Disassembling Flip Video Circuit Board: step 5, image 1 of 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Ask FixBot
    1. Disassembling Flip Video Circuit Board, Circuit Board: step 6, image 1 of 1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Ask FixBot
    2. Disassembling Flip Video Circuit Board: step 7, image 1 of 1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Ask FixBot
    3. Disassembling Flip Video Circuit Board: step 8, image 1 of 1
      • Disconnect the USB port cable from the back side of the circuit board.
      Ask FixBot
    4. Disassembling Flip Video Circuit Board: step 9, image 1 of 1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Ask FixBot
Author
with
Elizabeth
100 Reputation
6 Guides authored
Cal Poly, Team 26-21, Regan Spring 2010 Member of Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Members
72 Guides authored
1 Guide Comment
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 90
All Time: 3,065
