Disassembling Flat Iron Remington S-3500
  1. Disassembling Flat Iron Remington S-3500, What it looks like: step 1, image 1 of 2 Disassembling Flat Iron Remington S-3500, What it looks like: step 1, image 2 of 2
    • What the flat IRON looks like
    Ask FixBot
  2. Disassembling Flat Iron Remington S-3500: step 2, image 1 of 2 Disassembling Flat Iron Remington S-3500: step 2, image 2 of 2
    • Locate and remove the Hinge caps (One on each side)
    • On one side there will be a Philips screw below the cap
    • Take care. Screws seem quite soft, so find a well matching screwdriver
    Ask FixBot
  3. Disassembling Flat Iron Remington S-3500: step 3, image 1 of 1
    • Here you see the caps
    • Then the two "tube" like parts of the hinge/axle
    • Then comes the spring that forces the arms apart (Which came out just above where it is seen in the picture
    Ask FixBot
  4. Disassembling Flat Iron Remington S-3500: step 4, image 1 of 1
    • You can now access the three screws holding back the covers in both sides.
    Ask FixBot
  5. Disassembling Flat Iron Remington S-3500: step 5, image 1 of 1
    • Notice the spring to the right, when you put it together again
    Ask FixBot
  6. Disassembling Flat Iron Remington S-3500: step 6, image 1 of 1
    • The swivel on the mains cord is held back by 2 screws also easily accessible when the arms are separated
    • I bend the small pickups in the white part a little bit to make then just a bit tighter. (I dont know if this was the loose connection, but after assembly the blue light signalling heating started working again)
    • Caution, the parts inside carry (in my case 230 Volts) So checking for loose connections while taken apart should be done with an Ohm Meter or similar.
    Ask FixBot
Henrik Wahlberg
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 132
All Time: 721
