Up to 20% off select tools
Disassembling External Storage Hard drive
Views: 26K
View statistics:
Past 24 Hours:
11
Past 7 Days:
71
Past 30 Days:
261
All Time:
25,713
Comments: 5
5 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to open your Buffalo DriveStation Axis 2TB external storage and remove a faulty internal hard drive. To replace it, follow the directions in reverse with a new hard drive.
    1. Disassembling External Storage Hard drive, Disassembling External Storage Hard drive: step 1, image 1 of 1
      • Remove the screw marked with a red arrow to access hidden top tab.
      • Use a pointy tool to press the two tabs around the USB 3 connector. These are accessible via the holes marked with orange arrows.
      • You can slightly lift the back edge up to help free the tabs as you press them in. It doesn't take much to release them, so don't push too hard.
      Ask FixBot
    2. Disassembling External Storage Hard drive: step 2, image 1 of 2 Disassembling External Storage Hard drive: step 2, image 2 of 2
      • Along the top edge are the tabs marked in the first picture by the red circles. Use a thin-bladed screw driver to catch and pull back these tabs slightly to release the cover on this edge.
      • Lift on the cover slightly to ensure the tabs are released.
      Ask FixBot
    3. Disassembling External Storage Hard drive: step 3, image 1 of 2 Disassembling External Storage Hard drive: step 3, image 2 of 2
      • The front of the case has two tabs, marked by red arrows in the first pic. Repeat the process of using the screwdriver to gently release the tabs.
      • Continuing gently lifting on the cover while releasing the hidden tabs.
      Ask FixBot
    4. Disassembling External Storage Hard drive: step 4, image 1 of 1
      • The 3 red arrows indicate the hidden tabs on the last side. Repeat the screwdriver technique from the last two steps.
      • You should be able to remove the cover after all tabs have been released.
      Ask FixBot
    5. Disassembling External Storage Hard drive: step 5, image 1 of 2 Disassembling External Storage Hard drive: step 5, image 2 of 2
      • With the cover removed, the hard drive should be exposed--refer to the first picture to locate it.
      • Use the flat blade screwdriver to gently pry out the plastic case the hard drive sits in.
      • The hard drive is only held in the case with rubber bumper style mounts, and will come out with a little finger pulling.
      Ask FixBot
    6. Disassembling External Storage Hard drive: step 6, image 1 of 3 Disassembling External Storage Hard drive: step 6, image 2 of 3 Disassembling External Storage Hard drive: step 6, image 3 of 3
      • Remove hard drive from plastic case, flip over, and remove the two screws marked by red circles.
      • You will be left with the board and interface (seen in 3rd pic), ready to install your new hard drive.
      • Installation is the reverse of removal! Enjoy!
      Ask FixBot
10 other people completed this guide.
Author
with
HWgeek
307 Reputation
1 Guide authored
5 Guide Comments
Nice, easy and concise ‘how-to’. You made my task so much easier. Thank you!
Brian Puffer - Reply Share
Thanks..got the job done.
Jeff Willard - Reply Share
thank you for the blog. keep it up.
Sunil Das Shrestha - Reply Share
thanks.... just the job.
Stephen Foxall - Reply Share
My God I would never have been able to get this thing apart intact without this guide, THANKS !!
James McCarthy - Reply Share
Past 24 Hours: 11
Past 7 Days: 71
Past 30 Days: 261
All Time: 25,713
