Disassembling Ericsson CF 388 Phone Casing
Views: 1.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
95
All Time:
1,681
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
    1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: step 1, image 1 of 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: step 1, image 2 of 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: step 1, image 3 of 3
      • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
      • With your index finger, push in the button on the bottom of the battery to release it.
      • Pull the battery away from the phone.
      Ask FixBot
    1. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: step 2, image 1 of 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: step 2, image 2 of 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: step 2, image 3 of 3
      • After removing the battery, the front phone casing becomes accessible.
      • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
      • Remove these two screws using the Torx T6 Screwdriver.
      Ask FixBot
    2. Disassembling Ericsson CF 388 Phone Casing: step 3, image 1 of 3 Disassembling Ericsson CF 388 Phone Casing: step 3, image 2 of 3 Disassembling Ericsson CF 388 Phone Casing: step 3, image 3 of 3
      • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
      • Remove these two screws with a SP 2.6 screw driver.
      • Note: Remove gray plastic grommets with screws.
      Ask FixBot
    3. Disassembling Ericsson CF 388 Phone Casing: step 4, image 1 of 2 Disassembling Ericsson CF 388 Phone Casing: step 4, image 2 of 2
      • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
      • Note: Be careful not to damage the circuit board and components as you as open the casing.
      Ask FixBot
2 other people completed this guide.
Niccolas Tones
60 Reputation
9 Guides authored
Clemson, Team 1-1, Benson Spring 2012 Member of Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 95
All Time: 1,681
