Up to 20% off select tools
Disassembling Epson PPC650 Replacing Flash
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
91
All Time:
962
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling Epson PPC650 Replacing Flash, Case: step 1, image 1 of 3 Disassembling Epson PPC650 Replacing Flash, Case: step 1, image 2 of 3 Disassembling Epson PPC650 Replacing Flash, Case: step 1, image 3 of 3
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      Ask FixBot
    2. Disassembling Epson PPC650 Replacing Flash: step 2, image 1 of 1
      • Remove the two screws on the rounded side of the camera.
      Ask FixBot
    3. Disassembling Epson PPC650 Replacing Flash: step 3, image 1 of 2 Disassembling Epson PPC650 Replacing Flash: step 3, image 2 of 2
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      Ask FixBot
    4. Disassembling Epson PPC650 Replacing Flash: step 4, image 1 of 1
      • Remove the four screws from the bottom of the camera.
      Ask FixBot
    5. Disassembling Epson PPC650 Replacing Flash: step 5, image 1 of 3 Disassembling Epson PPC650 Replacing Flash: step 5, image 2 of 3 Disassembling Epson PPC650 Replacing Flash: step 5, image 3 of 3
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      Ask FixBot
    1. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: step 6, image 1 of 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: step 6, image 2 of 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: step 6, image 3 of 3
      • Optional: Remove two black screws from top of camera on the flash side for more working space.
      Ask FixBot
    2. Disassembling Epson PPC650 Replacing Flash: step 7, image 1 of 1
      • Remove clear rubber band holding flash in line with wiring.
      Ask FixBot
      • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
      Ask FixBot
      • Connect new flash by soldering copper ends to their respective ends to new flash element.
      Ask FixBot
Author
with
Xan Danes
134 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Spring 2013 Member of Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 91
All Time: 962
