Community-Contributed Guide
Needs Transcription
This guide is in video form only. Help make it more accessible by transcribing each action of the procedure into a separate step and adding photos.
Tools
Spudger4.9
Introduction
Use this guide to disassemble the DJI Mini 4 Pro drone to replace any broken or faulty parts. From replacing the camera gimbal and GPS module to tackling motherboard and ESC board issues, we've got you covered!
🔧 Tools & Tips: Learn what tools you need and how to keep track of those tiny screws and parts.
🛠️ Easy-to-Follow Instructions: Clear, detailed steps to help you through the entire process.
🚀 Reassembly Made Simple: Guidance on putting your drone back together for a successful repair.
Video Instructions
To reassemble your device, follow these video instructions.
11 other people completed this guide.
6 Guide Comments
Fantastic! My issue is losing connection even at 10 feet. I'm guessing the antenna is loose? Is there a guide to check the connections for the antenna?
Kevin - Reply Share
@kevin68196 test same remote on another drone first. Or try with another remote on your drone.
adrianTNT - Reply Share
@adriantnt I disassembled the drone and re attached the four arm connections. It worked great for 15 mins while flying and then lost signal again. Need to take it apart again.
Kevin Kaiser - Reply Share
@kevinkaise18799 I think some have hot glue on the antenna connectors to keep them in place, maybe that helps (if they popped out). Are the propellers OK? Maybe it causes excessive vibration. Just some ideas :)
@adriantnt I used hot glue but maybe it vibrated loose again. I should probably replace the propellers. They are original and are a little worn. Thanks!
