Up to 20% off select tools
Disassembling Compaq Mini 110 Speakers
Views: 3.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
91
All Time:
3,541
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
If your sound is not functioning properly these may be the problem. Check the troubleshooting guide before proceeding.
    1. Disassembling Compaq Mini 110 Speakers, Battery: step 1, image 1 of 2 Disassembling Compaq Mini 110 Speakers, Battery: step 1, image 2 of 2
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 2, image 1 of 3 Disassembling Compaq Mini 110 Speakers: step 2, image 2 of 3 Disassembling Compaq Mini 110 Speakers: step 2, image 3 of 3
      • Push both tabs inward simultaneously and slide the battery out.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, RAM: step 3, image 1 of 2 Disassembling Compaq Mini 110 Speakers, RAM: step 3, image 2 of 2
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 4, image 1 of 1
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, Keyboard: step 5, image 1 of 2 Disassembling Compaq Mini 110 Speakers, Keyboard: step 5, image 2 of 2
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 6, image 1 of 2 Disassembling Compaq Mini 110 Speakers: step 6, image 2 of 2
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Speakers: step 7, image 1 of 2 Disassembling Compaq Mini 110 Speakers: step 7, image 2 of 2
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Ask FixBot
    4. Disassembling Compaq Mini 110 Speakers: step 8, image 1 of 2 Disassembling Compaq Mini 110 Speakers: step 8, image 2 of 2
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, Hard Drive: step 9, image 1 of 1
      • Remove the three screws holding the panel in place.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 10, image 1 of 2 Disassembling Compaq Mini 110 Speakers: step 10, image 2 of 2
      • Pull up on the tab to remove the hard drive.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, Top Cover: step 11, image 1 of 1
      • Remove the eight screws that are from the plastic top cover.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 12, image 1 of 3 Disassembling Compaq Mini 110 Speakers: step 12, image 2 of 3 Disassembling Compaq Mini 110 Speakers: step 12, image 3 of 3
      • Pry up the top plastic cover using a spudger.
      • These two tabs under the screen need to be pushed in with a spudger.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Speakers: step 13, image 1 of 2 Disassembling Compaq Mini 110 Speakers: step 13, image 2 of 2
      • Remove the cable by carefully pulling it up.
      • Be careful when lifting up the cover because the track pad is still attached.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, Display Assembly: step 14, image 1 of 3 Disassembling Compaq Mini 110 Speakers, Display Assembly: step 14, image 2 of 3 Disassembling Compaq Mini 110 Speakers, Display Assembly: step 14, image 3 of 3
      • Remove the four screws that keep the bottom of the hinges attached to the base.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 15, image 1 of 3 Disassembling Compaq Mini 110 Speakers: step 15, image 2 of 3 Disassembling Compaq Mini 110 Speakers: step 15, image 3 of 3
      • Pry off the top plastic cover of the display assembly.
      • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
      • There is adhesive tape holding the cover on.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, Screen: step 16, image 1 of 3 Disassembling Compaq Mini 110 Speakers, Screen: step 16, image 2 of 3 Disassembling Compaq Mini 110 Speakers, Screen: step 16, image 3 of 3
      • Remove the 4 screws keeping the screen on the plastic assembly.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Speakers: step 17, image 1 of 3 Disassembling Compaq Mini 110 Speakers: step 17, image 2 of 3 Disassembling Compaq Mini 110 Speakers: step 17, image 3 of 3
      • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws.
      • The last picture shows the metal connectors that attach it to the display assembly.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Speakers: step 18, image 1 of 3 Disassembling Compaq Mini 110 Speakers: step 18, image 2 of 3 Disassembling Compaq Mini 110 Speakers: step 18, image 3 of 3
      • Detach the cable from the screen. It is connected under the foil flap.
      • The large wire on the back of the screen is for both the webcam and the microphone, as well as the screen.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Speakers, Speakers: step 19, image 1 of 3 Disassembling Compaq Mini 110 Speakers, Speakers: step 19, image 2 of 3 Disassembling Compaq Mini 110 Speakers, Speakers: step 19, image 3 of 3
      • Unscrew the speaker assembly at the bottom of the screen assembly.
      Ask FixBot
Author
with
Aleksander
288 Reputation
1 Guide authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 91
All Time: 3,541
