Up to 20% off select tools
Disassembling Compaq Mini 110 Power Pass-Through Board
Views: 5.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
90
All Time:
5,619
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
You may need to replace this board if there is something wrong when charging your device.
    1. Disassembling Compaq Mini 110 Power Pass-Through Board, Battery: step 1, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board, Battery: step 1, image 2 of 2
      • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Power Pass-Through Board: step 2, image 1 of 3 Disassembling Compaq Mini 110 Power Pass-Through Board: step 2, image 2 of 3 Disassembling Compaq Mini 110 Power Pass-Through Board: step 2, image 3 of 3
      • Push both tabs inward simultaneously and slide the battery out.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Power Pass-Through Board, RAM: step 3, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board, RAM: step 3, image 2 of 2
      • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Power Pass-Through Board: step 4, image 1 of 1
      • Push out the side tabs simultaneously and pull out the old RAM module.
      • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Power Pass-Through Board, Keyboard: step 5, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board, Keyboard: step 5, image 2 of 2
      • Remove the rubber pads located on the corners of your Compaq Mini.
      • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Power Pass-Through Board: step 6, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board: step 6, image 2 of 2
      • Unscrew all the corner screws. There are four total, one under each rubber pad.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Power Pass-Through Board: step 7, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board: step 7, image 2 of 2
      • Unscrew the screw for the bottom case located in the RAM compartment.
      Ask FixBot
    4. Disassembling Compaq Mini 110 Power Pass-Through Board: step 8, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board: step 8, image 2 of 2
      • Remove the three screws in the silver tabs at the back of the keyboard.
      • These are located at the back of the base under the screen.
      • Lift the keyboard away from the laptop.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Power Pass-Through Board, Top Cover: step 9, image 1 of 1
      • Remove the eight screws that are from the plastic top cover.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Power Pass-Through Board: step 10, image 1 of 3 Disassembling Compaq Mini 110 Power Pass-Through Board: step 10, image 2 of 3 Disassembling Compaq Mini 110 Power Pass-Through Board: step 10, image 3 of 3
      • Pry up the top plastic cover using a spudger.
      • These two tabs under the screen need to be pushed in with a spudger.
      Ask FixBot
    3. Disassembling Compaq Mini 110 Power Pass-Through Board: step 11, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board: step 11, image 2 of 2
      • Remove the cable by carefully pulling it up.
      • Be careful when lifting up the cover because the track pad is still attached.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Power Pass-Through Board, Hard Drive: step 12, image 1 of 1
      • Remove the three screws holding the panel in place.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Power Pass-Through Board: step 13, image 1 of 2 Disassembling Compaq Mini 110 Power Pass-Through Board: step 13, image 2 of 2
      • Pull up on the tab to remove the hard drive.
      Ask FixBot
    1. Disassembling Compaq Mini 110 Power Pass-Through Board, Power Pass-Through Board: step 14, image 1 of 1
      • Detach the cables.
      Ask FixBot
    2. Disassembling Compaq Mini 110 Power Pass-Through Board: step 15, image 1 of 1
      • Remove the two screws keeping the board in place.
      Ask FixBot
3 other people completed this guide.
Author
with
alea
1,441 Reputation
14 Guides authored
Cal Poly, Team 22-2, Maness Fall 2010 Member of Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Members
180 Guides authored
1 Guide Comment
I am so glad I found your website. I took my netbook in to a computer shop and told it would cost me $122 dollars to fix this power board piece. My AC Adapter socket is loose and wont hold the ac adapter plug anymore. To say the least, I was quite unhappy with that expense, as I only paid a couple of hundred dollars for this new. So, I bought the replacement piece on eBay for 12 dollars and will use this wonderful guide to fix this on my own. Even though I have done minor drive and cable changes in larger computers, I feel that your instructions are super easy and even an amateur like myself should be able to accomplish good results. Thank you.
gloriafeil - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 5,619
