Up to 20% off select tools
Disassembling Chef's Choice M115 Case
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
128
All Time:
2,864
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is the most important step. You will not be able to proceed to any other guides until you successfully open the case. Be sure to layout your magnetic project mat to lay your screws as you remove them and be extra cautious of the sharp edges after you remove the case.
    1. Disassembling Chef's Choice M115 Case, Case: step 1, image 1 of 2 Disassembling Chef's Choice M115 Case, Case: step 1, image 2 of 2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      Ask FixBot
    2. Disassembling Chef's Choice M115 Case: step 2, image 1 of 1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      Ask FixBot
    3. Disassembling Chef's Choice M115 Case: step 3, image 1 of 1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      Ask FixBot
    4. Disassembling Chef's Choice M115 Case: step 4, image 1 of 1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      Ask FixBot
4 other people completed this guide.
Author
with
Zachary Grounds
592 Reputation
3 Guides authored
IUPUI, Team 3-3, Harley Fall 2015 Member of IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Members
72 Guides authored
2 Guide Comments
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - Reply Share
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 128
All Time: 2,864
