Up to 20% off select tools
Disassembling Canon Powershot SD880 Menu Button
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
88
All Time:
1,988
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This may need to be removed if the button or scroll wheel is not working.
    1. Disassembling Canon Powershot SD880 Menu Button, Back Cover: step 1, image 1 of 3 Disassembling Canon Powershot SD880 Menu Button, Back Cover: step 1, image 2 of 3 Disassembling Canon Powershot SD880 Menu Button, Back Cover: step 1, image 3 of 3
      • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
      • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
      • One screw will be located under the rubber USB flap.
      • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Slowly pull the back cover off of the camera.
      Ask FixBot
    1. Disassembling Canon Powershot SD880 Menu Button, Menu Button: step 2, image 1 of 3 Disassembling Canon Powershot SD880 Menu Button, Menu Button: step 2, image 2 of 3 Disassembling Canon Powershot SD880 Menu Button, Menu Button: step 2, image 3 of 3
      • Remove 2 screws from back of camera using screwdriver.
      • Remove 2 screws holding metal side guard using screwdriver.
      • Remove the connecting ribbon by pulling it straight out.
      Ask FixBot
Author
with
Ben Tupas
329 Reputation
3 Guides authored
Cal Poly, Team 13-3, Forte Winter 2011 Member of Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 88
All Time: 1,988
