Disassembling Canon PowerShot SD800 IS LCD Display
    1. Disassembling Canon PowerShot SD800 IS LCD Display, Back Cover: step 1, image 1 of 1
      • Remove one 2.25mm screw on the bottom.
      Ask FixBot
    2. Disassembling Canon PowerShot SD800 IS LCD Display: step 2, image 1 of 1
      • Remove two 2.25mm screws on the right side looking from the front.
      Ask FixBot
    3. Disassembling Canon PowerShot SD800 IS LCD Display: step 3, image 1 of 1
      • Remove one 4.7mm screw on the side with the AV output.
      Ask FixBot
    4. Disassembling Canon PowerShot SD800 IS LCD Display: step 4, image 1 of 1
      • Pull off the back cover.
      • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
      Ask FixBot
    1. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Assembly: step 5, image 1 of 1
      • Remove 2 2.4mm screws on bottom.
      Ask FixBot
    2. Disassembling Canon PowerShot SD800 IS LCD Display: step 6, image 1 of 1
      • Follow the small data cable to where it connects to the camera.
      • Lift the back white portion to unlock the cable.
      • The cable should easily slide out.
      • The connector is very fragile. Use caution when lifting the lock.
      Ask FixBot
    3. Disassembling Canon PowerShot SD800 IS LCD Display: step 7, image 1 of 1
      • Gently lift LCD display off.
      • There will be two data cables still attached to the camera. Do not break them.
      • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
      Ask FixBot
    4. Disassembling Canon PowerShot SD800 IS LCD Display: step 8, image 1 of 1
      • Follow the larger cable to where it connects to the camera.
      • Lift the front black portion of the connector to unlock the data cable.
      Ask FixBot
    1. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Display: step 9, image 1 of 1
      • Pry the LCD display out from the four metal clamps.
      Ask FixBot
    2. Disassembling Canon PowerShot SD800 IS LCD Display: step 10, image 1 of 1
      • To remove the LCD, peel the larger data cable off from the frame.
      • The LCD is glued by its data cable to the back of the LCD frame.
      Ask FixBot
Jeremy Rabaino
135 Reputation
6 Guides authored
Cal Poly, Team 20-9, Maness Fall 2010 Member of Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 29
All Time: 3,161
