Disassembling Canon PowerShot SD800 IS Back Cover
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
90
All Time:
3,219
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 minutes
Difficulty: Very easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Removing the back cover allows access to the LCD display and the flash assembly.
Tools
    1. Disassembling Canon PowerShot SD800 IS Back Cover, Back Cover: step 1, image 1 of 1
      • Remove one 2.25mm screw on the bottom.
      Ask FixBot
    2. Disassembling Canon PowerShot SD800 IS Back Cover: step 2, image 1 of 1
      • Remove two 2.25mm screws on the right side looking from the front.
      Ask FixBot
    3. Disassembling Canon PowerShot SD800 IS Back Cover: step 3, image 1 of 1
      • Remove one 4.7mm screw on the side with the AV output.
      Ask FixBot
    4. Disassembling Canon PowerShot SD800 IS Back Cover: step 4, image 1 of 1
      • Pull off the back cover.
      • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
      Ask FixBot
Jeremy Rabaino
135 Reputation
6 Guides authored
Cal Poly, Team 20-9, Maness Fall 2010 Member of Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 90
All Time: 3,219
